PS Pump interchangablity from small to big block?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by talldogg, Sep 4, 2001.
  1. talldogg
    talldogg 1/2 ton status
    Jul 26, 2000
    754
    San Diego, CA
    I ordered the power steering pump brackets for the 454 Friday and while I was there I asked about the PS pump. According to the computer at the dealership the big block pump is different from the small block (at least the part number is). So my question is, will I be able to use the small block pump on the big block?? Or maybe it's just the pulley that differs? If so, anyone know of a place to get a cheap PS Pump pulley for the big block setup? Big time thanks!
    If it doesn't sit on a frame, then it isn't a truck.
  2. prjt_blzr
    prjt_blzr 1/2 ton status
    Mar 4, 2001
    352
    COS, CO
    The pumps themselves are the same. depending on the year and application the pulleys do vary. The other variable is that the BBC use a diffferent hose diameter for the remote filler. The BBC uses a three belt pulley. I've only seen two of the belts in use on any truck though so I'm not sure if you can use a SBC pulley. Hope this helps.
