PSC pump only or also need hydro assist?
Discussion in 'The Garage' started by Ned Kelly, Feb 25, 2007.
  1. Ned Kelly
    Ned Kelly 1/2 ton status Premium Member
    Mar 1, 2005
    903
    16
    Winnipeg, MB
    I've got a '89 Burb 1/2 ton to which I'm swapping my 1 ton drivetrain and 39.5 TSL's. Turning the tires on my K30 was straining the stock pump (K30 had the factory hydro-boost brakes - which will also go into the Burb).
    Anyways, to help with steering, I am thinking of getting a PSC pump with boosted psi and boosted flow. I don't want to run hydro-assist if not necessary. I am going to use ORD's ps box frame bracket to help prevent the Burb's frame from cracking. I think this should be enough. I know hydro-assist would help take pressure of the frame near the ps box, but I don't want to go this route unless REALLY necessary. I mostly do mud,snow, dd. No rock.
    My questions are.....
    I should be ok with just the PSC pump upgrade to turn those tires?
    http://www.pscmotorsports.com/index.php?cPath=138&osCsid=074604bf6903e4c6d35fee76a5e18ce8
    The 1/2 ton frame should be ok with just the ORD brace?
    http://www.offroaddesign.com/catalog/steeringkit.htm
