PSC steering ram
Discussion in 'The Garage' started by 4X4HIGH, Jul 13, 2006.
  1. 4X4HIGH
    Dec 14, 2001
    22,063
    70
    Pleasanton, CA.
    Who has a PSC ram? I received mine today and was surprised to see that it only has a .625" diameter shaft when it is clearly listed on their website as having a .75" diameter shaft and i also asked about it and they verified the .75" diameter over the phone. Can anyone who has the 1.5" bore cylinder please measure the shaft diameter for me.
  2. readymix
    readymix 3/4 ton status
    May 30, 2004
    6,706
    26
    Murrieta, California
    I am thinking about getting the same thing, so I also want to know.
    Someone e-mail my wife and tell her to give me the $$
  3. sandawgk5
    sandawgk5 3/4 ton status
    Oct 28, 2003
    6,881
    Kitsap County PACNORWEST
    Same goes for me I am gonna put slugs in with a welded front so I NEED my ram:D
    Ira
  4. willyswanter
    willyswanter 1/2 ton status GMOTM Winner
    Dec 24, 2000
    2,690
    Bakersfield, CA
    They sell both .625 and .75". What length and part # did you buy?
  5. 4X4HIGH
    Dec 14, 2001
    22,063
    70
    Pleasanton, CA.
    SC-2200K 1.5"Bore x 8"Stroke Cylinder Assist Steering Cylinder [SC-2200_]
    $183.00
    [​IMG] [​IMG]
    THIS CYLINDER IS BUILT TO ORDER-ALLOW AT LEAST 2 WEEKS BEFORE BEING SHIPPED
    1.5" Bore x 8" Stroke x .75 Rod w/ 5/8 heim joints, mount tabs & hardware
    Available Options:Hardware Kit:Without (part# 2200) (-$46.00)With (part# 2200K)
    This is the exact item i ordered and you can see where it says .75" rod.
  6. txfiremank5
    txfiremank5 1/2 ton status
    Jul 6, 2004
    3,105
    San Antonio, TX.
    As you know already, mine measured out to .625 as well. I bought from the exact add that is posted, becuase I had a direct link in my favorites .. so I just used that when I went to make my purchase. I "thought" I was buying a 1.5 ram, w/ a 3/4 rod as it stated.
    Guess it's time to play some phone tag and see what they will do.
  7. readymix
    May 30, 2004
    6,706
    26
    They did the same thing to me when I ordered the Hyd assist line kits. Ordered 2 kits with 90deg fittings and 8' of 3/8" weatherhead hose, of course I recieved the kits....but with only 6 feet of hose........
    The resolution I was offered was that they would send me an additional 10' of hose. That way I could make the kits work without having to splice the hoses.
    Oh, and they only wanted $44:angry1:, to fix a mistake that I had no control over....IE, not my fault.
    I hope your deal turns out better.
  8. txfiremank5
    Jul 6, 2004
    3,105
    San Antonio, TX.
    Yeah, let's hope so.
  9. 4X4HIGH
    Dec 14, 2001
    22,063
    70
    Pleasanton, CA.
    Well, i know my deal will work out better, i paid with a cc so i will just tell them if it isn't made right i will have a ram and stop payment until i am satisfied.
  10. 85mudblazin
    85mudblazin 1/2 ton status
    Mar 26, 2004
    3,951
    Austin,TX
    Should have went with Rocklogic like I told yall:p:
  11. 4X4HIGH
    Dec 14, 2001
    22,063
    70
    Pleasanton, CA.
    No thanks, not with -4 fittings, those are too small. Also the guy didn't know his a** from a hole in the ground when i called him on the phone.
  12. txfiremank5
    Jul 6, 2004
    3,105
    San Antonio, TX.
    CC for me too.
    Nah .. I still think I'd rather have this ram. Even if your RL has a full 3/4 rod, the end is still threaded into that, so it's smaller. I think I'll take my chances with the end threading over the rod. The material around that can be almost limitless in thickness (even if it means getting custom ends), where the inside is confined to the diameter of the rod. Besides, didn't you buy the full assist kit, only to turn around and buy new ends, hoses & fittings afterwards? :p:
    For my needs the .625 would probably never be an issue. But, the add says 3/4", and I also don't want to bend a rod (.625) and then feel like an idiot for not sending it back for the larger one. :doah: Besides, for all I know they may say it's not a problem and exchange it without any hassle. Won't know until I call.
  13. 4X4HIGH
    Dec 14, 2001
    22,063
    70
    Pleasanton, CA.
    Ok, i just got off the phone with Kelvin from PSC motorsports and he said that the 1.5" x 8" ram only has a .625" diameter shaft and that if you were to have a .75" shaft it would move too slowly in one direction. I told him that their website list the 1.5" ram as having a .75" diameter shaft and he told me that is incorrect and that he'll have to correct it. :mad:
    I am going to keep this ram and hope that i don't bend the shaft as so many other people have done. I'm sure that for my application i'll be fine considering i don't go climbing around on rocks or use heavy skinny pedal use to overcome an obstacle. It will also help that i now have the 1.5" diameter tie rod.
    I can say though that the PSC ram is one nice looking quality built ram. I do know where they are getting them from now since mine was shipped in the box that they got from their vendor. :thumb:
  14. readymix
    May 30, 2004
    6,706
    26
    and that vendor would be???
  15. 4X4HIGH
    Dec 14, 2001
    22,063
    70
    Pleasanton, CA.
    www.MertzEngineering.com
    From the looks of their website they only sell wholesale and not retail. Even if you could buy from them i'm sure there is a minimum order.
  16. txfiremank5
    Jul 6, 2004
    3,105
    San Antonio, TX.
    Isn't he the one who measured it on the phone, for you, and told you it was a .75? Did you bring up that point to him, and what did he say about it?
    Like I said, more than likely, I'll never have an issue with the .625. I'm not going to run a comp buggy w/ 49's or even 44's. I would imagine it will hold up plenty good for my needs. I could send it back and get something else, but I like every other aspect of the ram fine, so I'll probably just make do with it.
  17. 4X4HIGH
    Dec 14, 2001
    22,063
    70
    Pleasanton, CA.
    Yeah, i told him he was the one who verified the .75" shaft diameter and he denied it and said he would also have to check the website since it must be wrong if it says .75 shaft diameter.
    I like everything else about the ram as well so i'm keeping mine also. Like you said, not going to be extreme like some of the guys around here are so i should be fine.
    PS: i just went and took a look at PSC's website again to see if they corrected the mis-information that was there and here is what it says now.
    $183.00
    http://coloradok5.com/forums/images/PSC/assistcyl-sm.jpg&image=0
    1.5" Bore x 8" Stroke x .625 Rod w/ 5/8 heim joints, mount tabs & hardware
    Available Options: Hardware Kit: Without (part# 2200) (-$46.00)With (part# 2200K)
  18. readymix
    May 30, 2004
    6,706
    26
    So they Lied.......to you
    tried to half ass cover thier mistake......again to you
    And are going to do nothing about it.
    That is real crappy to hear, since I really want that ram. And they kinda did the same thing to me, those two things combined make me want to look elsewhere. but where?
    WTO = leaks
    AGR = crap
    RL = -4 JIC
    who else is there?
  19. ryan22re
    ryan22re 1/2 ton status
    Feb 5, 2005
    3,368
    Irmo, SC
  20. readymix
    May 30, 2004
    6,706
    26
    I looked at those, in a smaller size of course.
