PSI FOR 35X15X15 TSL SWAMPERS
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by 74chelsea, Sep 23, 2001.
  1. 74chelsea
    74chelsea Registered Member
    Mar 16, 2001
    39
    WHAT IS THE BEST PSI FOR A SET OF 35X15X15 TSL SWAMPERS IF YOUR JUST DRIVING AROUND TOWN, CAUSE I GOT SOME NEW ONES FOR THE TRAIL AND SOLD MY OLD ROAD SHOES.
    DUMB ?, BUT THANKS FOR THE HELP.
  2. Pure Insanity
    Pure Insanity 1/2 ton status
    Mar 17, 2001
    4,579
    Dade City, Florida
    LOL! I was gonna post the same question for 16x38x15 Swampers!
    I get all the exercise I need pushing my luck! [​IMG]
  3. dawson444
    dawson444 1/2 ton status
    Jul 5, 2000
    1,034
    Raleigh, NC
    I am also wondering that for 36x12.5x15 TSL Radials.
    Dawson
    Raleigh, NC
    88 K5, 6" lift, 36" TSL Radials, 14 Bolt, Rancho 9012s
  4. xnoahx
    xnoahx 1/2 ton status
    Oct 12, 2000
    817
    Ventura, CA 93004
    I heard that 30 is a good level for street, thats what im running my 36x12.5x15 TSL's
    My 73 K5 <a target="_blank" href=http://www.geocities.com/xk5blazerx/73k5.htm>http://www.geocities.com/xk5blazerx/73k5.htm</a> 350/TH350/NP203, Q-jet, Edelbrock intake, Vortec heads, 4" lift, and 36" TSL's
  5. RedDwarf
    RedDwarf 1/2 ton status
    May 9, 2001
    816
    North Central Florida
    Maybe for a loaded one ton!
    I assume we are talking K5 here...
    35": run about 18 psi
    36" radial: about 20 psi
    38": about 16-18 psi
    These big tires don't need much pressure because they have a lot more square inches than stock size tires.
    When in doubt, do the chalk test. Chalk the tread and drive a little ways on pavement. You want as much tread in contact with the road as possible.
    Poundin' the ol "pavment"!
  6. michaelm
    michaelm 1/2 ton status
    Feb 2, 2001
    872
    round town i ran my 38.5/16/16.5 @ 24psi
    better bump it up for the highway though.
  7. RedDwarf
    May 9, 2001
    816
    Yeah, but due to the exchange rate, air is not as dense in Canada.
    BTW, didn't your swampers ride rough and wear out fast???
  8. michaelm
    Feb 2, 2001
    872
    yup destroyed em in no time.
  9. hammer
    hammer 1/2 ton status
    Aug 29, 2001
    449
    Binghamton N.Y.
    run 50 psi cold for 32x11.5x15 on the street. 2 years old no wear. The side wall says 50 psi cold
  10. jarheadk5
    jarheadk5 1/2 ton status
    Mar 6, 2000
    4,389
    PA
    That's the maximum inflation pressure, to carry the maximum safe load. That's not necessarily the pressure you should run, unless you're loading your vehicle to the max safe load limit of the tires.
    If the tire says 50psi and is rated for 2000lbs, but that tire only has 1000lbs of weight on it, then it's gonna ride like a brick and wear out the tread center long before the outsides.
    Best bet is to do the chalk trick, or the water trick (spray tire tread with light mist of water from an old Windex bottle, roll vehicle until tread leaves a wet impression on the ground. Adjust pressure until the wet mark is even across the tread.).
    September 11, 2001--"A date which will live in infamy"
