PSI on BFG's
Discussion in 'The Garage' started by CHEVY 4WD, Aug 13, 2002.
  1. CHEVY 4WD
    CHEVY 4WD 1/2 ton status
    May 14, 2002
    1,773
    Florida
    PSI on BFG\'s
    What psi is good to run in 33 12.50 15 BFG AT's on the road?
    And what a good psi off offroad?
  2. kumma
    kumma 1/2 ton status
    Oct 29, 2000
    380
    Novi, Michigan
    Re: PSI on BFG\'s
    the tire place set mine at over 40 when i bought them. it rode quite stiff so i have lowered them to around 30 for the street. off road cant help every time i plan a trip the damn truck breaks down. /forums/images/icons/crazy.gif
    only put around a thousand miles on them since last november so i reaaly cant say how it effects the wear.
  3. txbluethunder
    txbluethunder 1/2 ton status
    Jan 29, 2002
    835
    Austin, TX
    Re: PSI on BFG\'s
    may not be the same but with my goodyear mt/r's i run 32 onroad and 15 offroad.
  4. TopOff
    TopOff 1/2 ton status
    Jan 16, 2002
    1,760
    Folsom, ca
    Re: PSI on BFG\'s
    What width rims are you running?
    You will get different PSI for different rim widths and different load carrying capacity.
    A stock Blazer vs a 1 ton Big Blocked, all accessories Blazer will make a different weight truck, and will need a different PSI in the tires.
    On my 35 12.5 16.5s I run ~26-30 PSI on the street. This is because I have 16.5 x 8" rims. A wider rim, I will probably have more PSI.
  5. Grim-Reaper
    7,385
    Atlanta
    Re: PSI on BFG\'s
    I'm running 30 front 28 rear on 35's that are rated 35 psi max. So far they are wearing even. WHen I trailer I run 30 30.
  6. four_by_ken
    four_by_ken 1/2 ton status
    Jun 9, 2001
    3,806
    Allenton, MI
    Re: PSI on BFG\'s
    On my susburban 33s.. I run at almost 50 psi. With anything lower, they bulge real bad.
    These are 16.5s.
    Ken H.
  7. BJarvis354
    BJarvis354 Registered Member
    Jun 17, 2002
    58
    New York City
    Re: PSI on BFG\'s
    Here is the spec sheet from BFG for the A/T KO.
    I run like 35~40 PSI on the road, cause otherwise the seem soft and mushy on the highway. Max for me is 50.
    Brady
  8. Grim-Reaper
    7,385
    Atlanta
    Re: PSI on BFG\'s
    First thing first....read the sidewall. Some BFG's are rated 35 PSI max and some 50PSI max. My set of 32's and my wies set of 31's are rated 50PSI. THe factory rally is only rated 40PSI. I ran the 32's for FIVE years and about 30k. At 36 front and 34 rear the wore dead even accross the tread. Now when you look at the PSI rating it will read something like "Max load of 2430lb at 35PSI". That per tire so all four tires combined could hand almost 10,000 lb! K5 depending on how much junk you have in it only weighs about 5500lb with 2 adults. If you run 35 psi it's going to rattle your teeth out because there is not enough weight to let the radial tire do it's thing. It's also balooning the tread and causing the center to wear faster.
    THERE is no reason to run Max pressure on the tire...if you got that much weight IN the truck the truck is grossly over loaded.
    Bulge is not a bad thing on a radial tire....it's a normal thing. Running to much air pressure will wear out the center of the tread. Too little whe wear out the shoulders faster. For a K5 on a large tire like a 33 if the side wall say's 35 max then 28-30 seems about right for me. THe heavier the truck the higher PSI you need to run. Keep a close eye on the tire wear...the fronts will wear the shoulders faster because they tak a lot more lateral loading when your turning. Keep them rotated and the back tires are the better gage if your running the right air pressure.
  9. Sandman
    Sandman 3/4 ton status Author
    Apr 15, 2002
    5,653
    Pocatello, ID
    Re: PSI on BFG\'s
    Run as little as you can off road. For normal off-roading, I run 10 pounds and rarely blow one off. In real deep snow I go to 4~5 pounds without beadlocks. Got to be careful at that pressure. If you hit some bumps you can here the tire "burp" but it makes a huge difference between 10 and 5 pounds.
