PTO info
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by RUSS84K5, Mar 9, 2001.
  1. RUSS84K5
    RUSS84K5 1/2 ton status
    Jan 9, 2001
    172
    NEW HAMSHIRE
    anybody,
    do the 203 and 205 use the same PTO unit?
    Dose the drive line have to be in nuatrel to run the PTO
  2. dyeager535
    26,979
    Not sure about 203/205. Was thinking about the neutral thing..while obvious safety concerns can be raised, I think you could leave the PTO engaged and have the transfer case in 2hi, 4hi, etc. Your winch would never keep up if you started moving quickly though. Best to pull yourself out letting the winch do the work.
    Once when I was a kid I hit the PTO knob in my dads truck. On the 75 mile ride home, we kept hearing this weird "ka-thunk" noise every once in awhile. I was so young I don't remember what happened, but I believe it snapped the pto drive shaft after about 50 miles. Winch is still on his truck and works fine though!
    Dorian
