PTO On A AutoMatic? Will it Work?
Discussion in 'The Garage' started by Looksback, Apr 14, 2003.
  1. Looksback
    Looksback 1/2 ton status
    Aug 12, 2002
    120
    Montana
    Is there any way to put a PTO on a automatic transmission, I have a '74 1 ton 2WD, and I need to try to connect a PTO for a water pump, But I have not idea if thay can be connected to a automatic. The transmission is a TH350 2WD.
    Thanks For The Help
    LooksBack
  2. LKJR
    LKJR 1/2 ton status
    Apr 18, 2000
    2,116
    Lubbock, Tx
    someone else that has a little more experience will probably chime in here after me. but off the transmission itself probably not. Most pto kits run off of a gear drive, hence the adaption to the 465 tranny and the 205 tcase. I think there is an inline setup that you can get that goes behind the tranny and is like a gearbox that disengages the drivetrain so you can run it but don't take my work on it. Good luck, hopefully you will find something that isn't too expensive
  3. 6.2Blazer
    6.2Blazer 1/2 ton status
    Feb 24, 2000
    4,675
    26
    Ohio
    We have a 2wd automatic pickup at work that runs a water pump off of the driveshaft. I can't remember right off hand if it is chain or belt driven, but basically there is a sprocket on the driveshaft and a chain that runs to another gear box. The driveshaft is a two piece design and the sprocket is obviously on the part that runs from the tranny to the carrier bearing, thus meaning that there is very little movement.
  4. Looksback
    Aug 12, 2002
    120
    Montana
    hmm, would any body here know where to gett on of these kits for a PTO? know I need one but like a lot of people I dont have a lot of money, thats why I have not gone to a farm supply yet.
    Thanks For THe Help
    LooksBack
  5. Don
    Don 1/2 ton status
    May 30, 2002
    1,778
    Spokane Washington
    Do You want to use the pto, when the vehicle is in motion? Cause that's the only way it's gonna work. /forums/images/graemlins/shocked.gif
  6. Looksback
    Aug 12, 2002
    120
    Montana
    no, it would have to be parked, becuase it will be for pumping water out of a well that is about 75~100 feet deep, and I need to gett as much of it to the serface as soon as possiable, I am starting to think of a electric water pump that can be powered off the 12 volt battery, but I have been looking at those today and thay are vary expensive.
    Thanks For The Help
    LooksBack
  7. Don
    Don 1/2 ton status
    May 30, 2002
    1,778
    Spokane Washington
    Too bad it is'nt a 4x4. That way You could run one off of the T-Case, it's a no-brainer from there. /forums/images/graemlins/crazy.gif
  8. 83ZZ502_Jimmy
    83ZZ502_Jimmy 1/2 ton status
    Feb 7, 2001
    3,103
    Richmond, VA
    Well, that brings up an interesting thought. If he has a standard turbo 400 tranny with a 4.5" tailshaft, he could get a 205 and adapter to bolt it onto the tranny. Then get the rear driveshaft shortened, or even possibly a d-shaft from a donor truck for the rear. One could then use the t-case for said pump.
    Just a thought,
    John
    On edit: I just read that he has a t-350 tranny. This could still work, just with a different tranny. I dunno, just throwing ideas around
  9. Looksback
    Aug 12, 2002
    120
    Montana
    another thing, if that would work, would it fit because of the floor pan being lower on a 2WD cab? at this point I am up for a bout any idea, need to gett water fast, its getting hard and expensive trying to gett water from town, or lakes.
    Thanks for the help
    LooksBack
  10. 83ZZ502_Jimmy
    Feb 7, 2001
    3,103
    Richmond, VA
    I dont think there's a difference, but I could be wrong. I think the floor is the same for 2wd and 4wd trucks. Keep us posted.
    John
  11. Looksback
    Aug 12, 2002
    120
    Montana
    The floor pan in a 4WD is higher than a 2WD, that why there is room for the transfer case. Also today was the first time in a week there was no mud on the ground, so I gott under the truck to seen if there was a PTO cover on the TH350, and just as I though it would be there was none. After the output shaft there is a short driveshaft that oes into a coupler that is mounted on to the frame, and I was looking at the gear box that mounts over the PTO cover, and I was thinking what if a transfer case could be mounted in a high up postion between the frame rails thaty a normal drive shaft go the the rear diff?
    Sounds like a lot of work, and it probly is, so it might no be worth the effort?
    LooksBack
