PTO with auto tranny?
Discussion in 'The Garage' started by Russell Keys, Nov 29, 2002.
  1. Russell Keys
    Russell Keys 1/2 ton status
    Mar 16, 2000
    253
    Huntsville, TX
    Is it possible to run a PTO winch with an automatic transmission. What would disadvantages be vs. man. tranny?-Russell
  2. Grim-Reaper
    7,385
    Atlanta
    On a 203 and a 205 yes you can. No advantage no disadvantage. SM465 manual can run a PTO also.
  3. u2slow
    u2slow 1/2 ton status
    May 9, 2001
    2,217
    BC Canada
    PTO on manual tranny gives you a single speed.
    PTO on t-case gives you as many speeds as your manual tranny has... plus reverse.
    Of course, a PTO unit can be had as a simple engage/disengage, or a forward/disengage/reverse.
  4. Looksback
    Looksback 1/2 ton status
    Aug 12, 2002
    120
    Montana
    This is sort of off the subject, but I have a PTO winch that I have been trying to gett rid-of, I do not know what LBS range it is, but the cable on it is 1" approx diameter, it has all of it drive lines, it just needs the control box that mounts is the cab. Mounted on a '73-'75 style bumper. I can post a photograph if you are intrested.
    LooksBack
  5. BiggerRigger
    BiggerRigger Registered Member
    Nov 3, 2002
    81
    C.D.A. Idaho
    how does ths work do you put the transfer in "n" and that engages the pto or am I looking at this wrong
    Aaron
  6. Looksback
    Aug 12, 2002
    120
    Montana
