PUBLIC SERVICE ANOUNCEMENT!!!!for real
Discussion in 'The Lounge' started by boggerless, Mar 19, 2007.
  1. boggerless
    boggerless 1 ton status Premium Member
    May 26, 2003
    22,728
    96
    dearborn heights, Michigan
    clean your clothes dryers!!!i have had two friends have thier houses burn to the ground cuz of dirty dryers.very sad. and i don't want to hear about anyone of you guys or your family members dying cuz of something so simple to fix.last saturday my wifes dryer was on fire.she called to say the house was filling with smoke. it was 2pm.she last ran the dryer at 1am that night.it was smoldering.SO LOOK AND CLEAN THOSE THINGS!!!!!!!!:yikes: :yikes:
  2. dogdaysunrise
    dogdaysunrise 1/2 ton status
    Jan 19, 2005
    2,719
    Winterpeg
    Thanks for the heads up Daryl.
  3. boggerless
    May 26, 2003
    22,728
    96
    i preach it to people all the time,including my wife.she would get pissed at me."don't tell me what to do,i'm an adult".i did say "SEEE".when the Fire department showed up.:D lint does get past the catcher.one of the Fireman told her most of the runs they go on is a dryer fire!;) but for ten years i was "paranoid".:deal:
  4. thezentree
    thezentree 3/4 ton status
    Sep 19, 2003
    7,198
    NC
    I can ignore this because I don't have to worry about it.
    My apartment doesn't have a washer or dryer. But I am listening to BB King.
  5. boggerless
    May 26, 2003
    22,728
    96
    BB King is all good!!:woot: :woot: :woot:
  6. ryoken
    Jun 13, 2003
    29,624
    1,380
    Jersey Shore
    my neighbor had a dryer fire...
    i completely disassembled mine a few years ago and cleaned it out... amazing how much lint was trapped down in by the fan, etc.. not to mention it works sooooo much better...
  7. GotLabs
    GotLabs 1/2 ton status GMOTM Winner
    Jul 30, 2005
    2,795
    Transient, USA
    Thanks for the reminder, I need to clean my junk again.
  8. 4xcrazy
    4xcrazy 3/4 ton status
    Oct 31, 2003
    9,472
    5
    Olympia/Lacey, Washington
    Something else you need to check every now and then is the lint trap screen...
    I received an email awhile back telling me about this little deal. There are chemicals and whatnot in fabric softeners, that believe it or not,,,clog up your lint traps.
    They look absolutely clear to the eyes, but if you run them under water, they will hold that water,,,,a screen,,,,
    They need to be run under warm water and scrubbed clean every so often.
    This also depends on how much you use your dryer. I tried this with our old one, and it freaked me out when the screen lint trap, held the water i had running in it.
    This will cause overheating and other problems inyour dryer.
  9. dogdaysunrise
    Jan 19, 2005
    2,719
    Winterpeg
    Well I am pretty sure that my dryer is around 7 or 8 years old and it may be time to do these things.
  10. pauly383
    Jul 22, 2001
    16,217
    Mesa , Arizona USA
    I sell the long brushes to go in the tubing in the wall , new lint filters , small brushes to go in the lint trap area .
    Scary , let me tell you , six months of dryer use can coat the floor of your dryer with lint . They are NOT air tight , those felt seals and the foam rubber around the blower housing DO LET AIR , AND LINT escape :eek1:
    No biggie though , if your a guy , take it apart once in awhile for the wifey . Its what men do , tinker with chit :D
  11. 70jimmy
    70jimmy 3/4 ton status Premium Member GMOTM Winner
    Mar 3, 2000
    5,962
    251
    Released from Pueblo, told I belong in Southpark
    yep I tear the back off mine every year or two and also do the hot water and brush thing to the lint trap. I also replace the hose between the dryer and wall when I clean it.
    another good hint is to shut the water supply off to your washer when you are going on a trip. If the hose develops a leak it will run until you get back or you flood the street and somebody notices and calls someone who cares.
    I have had two friends houses burn down due to a dryer fire.
  12. pauly383
    Jul 22, 2001
    16,217
    Mesa , Arizona USA
    Hey stranger and driveshaft changer , like your user title :thumb:
  13. 70jimmy
    Mar 3, 2000
    5,962
    251
    hopefully that title will change soon. :o
  14. CDA 455
    CDA 455 3/4 ton status
    Jun 2, 2006
    8,598
    43rd State
    Thanks for the heads up!
  15. Russell
    Russell LB7 Tahoe Status Premium Member GMOTM Winner
    Jun 23, 2000
    7,925
    337
    Fort McMurray, Alberta
    Gotta pull the dryers at the apartment apart once a month to pull the 6 inch wad of lint that collects in the fan shaft, and around the heater... Scary how fast it builds up!
  16. boggerless
    May 26, 2003
    22,728
    96
    i forgot that part.one of thr firemen said the exact same thing.and something about laundry detergent messes up your furnace. this has happened to mine.it's too close the the washer.
  17. boggerless
    May 26, 2003
    22,728
    96
    my tubing is easy to change so i do that.i need to check my lint trap though.water test....:D
  18. boggerless
    May 26, 2003
    22,728
    96
    my wife NEVER cleaned the lint trap.:rolleyes: and thought i was being an ass for telling her to do it.so i made a daily habit to check it myself.:waytogo: i don't want to wake up dead.
  19. 79k20350
    79k20350 3/4 ton status
    Nov 22, 2004
    7,757
    Ct
    This is why you NEVER use flex pipe for the exhaust... You should only use solid steel piping with real elbows.. The lint will get caught in the nooks/ crannys of the flex...
  20. boggerless
    May 26, 2003
    22,728
    96
    yes sir!!cheap can mean death.
