puking oil into the tbi
Discussion in 'The Garage' started by chvymudin3388, Jan 24, 2007.
  1. chvymudin3388
    chvymudin3388 1/2 ton status
    Mar 3, 2005
    374
    orange grove ,tx
    blowing smoke up through the tbi while running like a blue smoke and you see the motor sucking it in you rev the motor up and a whole lot comes out and it sucks it in
  2. 1977k5
    1977k5 3/4 ton status Vendor
    May 26, 2003
    9,994
    130
    Ummmmm, English?
  3. chvymudin3388
    Mar 3, 2005
    374
    orange grove ,tx
    uhm its puking oil out of the driver side breather tube going into the tbi. i havent seen it spit oil in it yet but its all over the top of the tbi. ive seen it blow the blue smoke like crazy.
  4. Jason4x4
    Jason4x4 1/2 ton status
    Nov 5, 2006
    4,505
    6
    Chandler, AZ
    check your pcv, and make sure the port for the pcv at the tbi isn't plugged
  5. HarryH3
    HarryH3 1 ton status Author
    May 31, 2000
    10,384
    Georgetown, TX
    Remove the oil fill cap and start the engine. If you feel air blowing out of the valve cover, then you have a serious blowby problem. The only fix for that is a rebuild. :(
  6. chvymudin3388
    Mar 3, 2005
    374
    orange grove ,tx
    ill try it in the morning and by blow by do you mean in the heads or the piston rings and i just rebuilt this motor like 3,000 miles ago. new ringd head job all new seats all new bearings and honing of the cylinders
  7. HarryH3
    May 31, 2000
    10,384
    Georgetown, TX
    Blowby is combustion pressure getting past the rings and down into the crankcase. Not a good thing. :(
  8. MaxPF
    MaxPF 1/2 ton status
    Apr 13, 2006
    2,207
    Chandler, Arizona
    Were the cylinders just honed, or bored and then honed? I've seen a lot of rebuilds where the tapered, out-of-round bores were ball honed, a new set of rings thrown in, and they run it. The result is predictable - poor compression and lots of blowby :doah:. Ball hone rebuilds only work if the motor is low-mileage and has no taper or out-of roundness in the cylinder. Anyway, it sounds like a lot of blowby to me as well. Even if the PCV is plugged a healthy motor shouldn't spew that much oil or smoke from the breather tube...
  9. 1977k5
    May 26, 2003
    9,994
    130
    I think that "rebuilt" motors are much more likely to have blow-by issues than stock motors with high mileage. There are tons of people that either do half assed rebuilds or have actually never rebuilt it and claim that it has had a rebuild.
  10. goldwing2000
    goldwing2000 Guest
    Check the PCV system first, though. It's easy enough to check (and fix).
  11. chvymudin3388
    Mar 3, 2005
    374
    orange grove ,tx
    lovely .. i tihnk ill go cry like a baby lol its got blow by bad it shoots past your fingers out of the oil fill:(
  12. Col_Sanders
    Col_Sanders 3/4 ton status
    Apr 27, 2005
    5,688
    KFC
    Could be worse...You could have had a motor built, then added performance heads, cam, and intake, installed by a friend that "knew" what he is doing, and less than 3k miles later have a blown head gasket because the friend didnt torque the heads right and used RTV on the head gasket. Oh yeah, it blew a couple days before I moved over 1000 miles. :doah:
    Did you at least get a warranty or did you do it all yourself? If you dont have a warranty, have your next motor built by a good shop that will give you a warranty and go bigger.:pimp:
  13. chvymudin3388
    Mar 3, 2005
    374
    orange grove ,tx
    well the part that sucks the most is i was fixing to sell the truck as much as i dont want to... and im broke and cant afford the rebuild. all i really need to do is go back in have the block bored and put in new pistons and rings everything else is new.
  14. Col_Sanders
    Apr 27, 2005
    5,688
    KFC
    Never happens at a convenient time. Good luck man.
    BTW where is orange grove?
  15. goldwing2000
    goldwing2000 Guest
    Measure the bores (or have them measured) before you go dropping coin on new parts. It might be something simple (and dumb) like all the ring gaps lined up or something.
    Do a compression check before you tear it apart and see what the numbers look like.
    Always start with the simple things first.
    And still check out your PCV system.
  16. chvymudin3388
    Mar 3, 2005
    374
    orange grove ,tx
    its like 30 miles south of corpus christi which is like around 200 south of houston
