Pull With Big Tires Or Small???????
Discussion in 'Tow & Trailer' started by JEBSR, May 7, 2006.
  1. JEBSR
    JEBSR 1/2 ton status
    Dec 23, 2004
    1,541
    Clarksville, TN
    My truck won't fit on my trailer without running over my fenders and crushing them. I have two options that I see.Put braces over the fenders and drive over them, or put on smaller tires to tow.
    I am thinking that with the smaller tires it will lower my center of gravity making the trailer more stable should I have to change lanes fast or something. Is this true or does it really matter?
  2. divorced
    divorced 3/4 ton status
    Jul 20, 2004
    5,115
    My friend used 1/4" diamond tread plate to make his fenders. They work great for driving on... it's a PITA to always swap tires, especially when they're muddy.
  3. kyser_soze
    kyser_soze 1/2 ton status
    Sep 4, 2004
    3,180
    KC Missouri
    I'm lazy
  4. kyser_soze
    Sep 4, 2004
    3,180
    KC Missouri
    I'm lazy
  5. Greg72
    Mar 5, 2001
    15,683
    1,392
    642 Days to BB2018
    You could use wedge shaped wooden blocks on the platform (sort of like what's depicted on kyser soze's trailer). Just make them tall enough that the tires won't touch the fender skirts.
    I've seen guys swap out only the two front tires to get the clearance...but it does seem like a pain to pull tires on/off every time.
  6. JEBSR
    Dec 23, 2004
    1,541
    Clarksville, TN
    Thanks for the replies, I was thinking of something like Kyser has but removable for when I pull other cars. The wooden blocks would certainly fit the bill.
  7. rjfguitar
    Aug 28, 2002
    9,097
    144
    california
    You mean like this?:doah:
    I had to pull all 4 tires because I couldn't get the K5 forward enough with the boggers on back to get the weight right. It was a big pain in the sit down place.:D
    Luckely, Shaggy was nice enough to lend me his compressed air and impact gun to make things a little quicker at camp when I arrived. Needless to say, it was a lot of work and plan on using a deck over trailer this year so I don't have to remove the wheels and tires.
    As far as stability, no, I don't think it makes any kind of difference with either size tires.
  8. nova
    nova 1/2 ton status
    Mar 9, 2003
    285
    Laporte, IN
    You should just build new fenders from scratch. Just make them alot stronger and angled. If you build removable ramps that would just be more to carry around, or to keep track of. New fenders and there is no more parts and you would be able to load up whatever you want.
  9. kyser_soze
    Sep 4, 2004
    3,180
    KC Missouri
    These are removable, there bolted into the deck. They alsocan be pulled in half.
  10. DEMON44
    DEMON44 Low-Tech Redneck
    Jan 8, 2003
    7,232
    15
    Okotoks, Alberta
    I've got 1/4" flatbar welded to reinforce the fender to drive over. Still get a car in the middle and no yanking tires all the time. It doesn't make the fenders any narrower in between. and plenty strong enough for big stupid trucks. This trailer used to haul Wolf359 the fenders held the land cruiser with 44's, I picked it up from him. You can see the widened deck too.
  11. mouse
    mouse 1/2 ton status
    Nov 10, 2003
    1,448
    Great Falls Mt
    How about this?
  12. JEBSR
    Dec 23, 2004
    1,541
    Clarksville, TN
    Hell I like that, Currently either changing tires or putting wood along side the fender to go over. I've got to go get some measurment and see if I can do that or not. Trucks pretty wide with rims/tires I'm running. My fender is also solid welded at the bed, but I could cut that.
  13. mouse
    Nov 10, 2003
    1,448
    Great Falls Mt
    Mine WAS welded to the bed as well...
  14. vtblazer
    vtblazer 1/2 ton status GMOTM Winner
    Sep 30, 2003
    2,471
    Central VT
    Or another fender mod option could be done this way...
  15. 6.2Blazer
    6.2Blazer 1/2 ton status
    Feb 24, 2000
    4,675
    26
    Ohio
    I stacked three leftover 4x4 wood pieces together on each side and then cut the ends at an angle to drive over. These ramps than have a couple pieces of 2x4's running vertical on the inside edge to hold them together, then I ran a couple bolts through the 4x4's and into the side of the fenders. I've been using this setup for years and have never had a problem.
    To remove them for hauling a car or something, you simply remove two nuts on each side and pull them off. They are plenty light enough for one person to easily move them around. The other nice thing is that I ran 2x4's cross ways between the two ramps to make a little firewood/parts holder in this area.
    The problem with just reinforcing the stock fenders is that they are too far apart and only about 2-3" of the tire on each side would make contact with them, making it really hard to load and unload without having a tire slip off.
    Making more permanent inner fender extensions/ramps are a pain if you ever need to hauls something like a car that won't between them.
    I originally thought about removable fenders, but decide those would be a pain. Especially since the correct weight distribution of the Blazer on the trailer would require either perfect placement of the rear tires, or pull the front tires past the fenders, get out and reattach the fenders, and then pull rest of the way forward. If the rear tires were slightly off center you coundn't get removeable fenders back on.
