Pullies on a 1986 Blazer/Jimmy
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by sandracer799, Feb 10, 2004.
  1. sandracer799
    sandracer799 1/2 ton status
    Feb 10, 2004
    834
    Richmond,Virginia
    Did the 86 blazer/ jimmy come with the semi serpentine set-up? Also has anyone ever used the semi serpentine set-up that has A/C on a engine with Vortec Heads. If so did you have to make any mods to it.
    Thanks in advance
    Josh
  2. rjfguitar
    Aug 28, 2002
    9,096
    144
    california
    87' was the first year for a semi serpintine setup. Far as I know 86 and earlier still had all v-belts. My 85' has v-belts.
  3. moneypit
    moneypit 1/2 ton status
    Sep 3, 2000
    1,382
    COLORADO
    My 86 is semi-serp. /forums/images/graemlins/thumb.gif
  4. beater_k20
    beater_k20 Banned
    Dec 9, 2003
    10,276
    Elkhart, IN
    mine is semi serp too
  5. tarussell
    tarussell 1/2 ton status
    Dec 28, 2002
    1,354
    Bagdad , FL
    My 1986 K-5 came with a multi-groove belt for the alt. and regular V-belts for the P/S and A/C and they are the same pulleys that are on a 1987 T.B.I. parts Blazer that I had .
  6. rjfguitar
    Aug 28, 2002
    9,096
    144
    california
    I guess 86' was the first year for some sort of serpintine setup, not 87'. /forums/images/graemlins/doah.gif
  7. 83ZZ502_Jimmy
    83ZZ502_Jimmy 1/2 ton status
    Feb 7, 2001
    3,103
    Richmond, VA
    Where in VA are you? Nice to see another VA member. /forums/images/graemlins/wink.gif
    And yes, 1986 is the 1st year for the semi serp setup.
    John
  8. dyeager535
    26,979
    Vortec heads shouldn't make any difference for the pulleys, they have the same accessory holes as all earlier heads. (3 per end of head)
    Semi-Serpentine I *think* first started in 1985 on the Monte Carlo's with the 305, and is what I've got on my truck with Vortec heads, but I don't have AC. Compressor is DS right? Even with semi-serpentine I believe the AC is run off of a v-belt.
    On my setup, serpentine runs water pump and alternator, V to the PS pump.
    you can see the two "empty" water pump V-belt grooves
  9. 83ZZ502_Jimmy
    Feb 7, 2001
    3,103
    Richmond, VA
    When he says pullies, I think he is referring to how the brackets bolt to the intake manifold and heads. Since the vortec intake is 8 bolts straight down instead of the 12 on an angle, it may make the brackets difficult to bolt-on.
    I know on one particular motor that I converted to Vortec, I could not reuse the existing brackets/pullies for this exact reason. Too much relied on the intake for support.
    John
  10. dyeager535
    26,979
    Very bizarre...none of the other replies showed up until yours did.
    Ahh, brackets to intake manifold, yeah I can see this being a problem. AC has one that goes to the intake, correct?
    TPI threw me a whole 'nother problem, but it too was bracket related.
    Can perhaps a '96+ truck AC setup work, or did the AC system change enough by then that the brackets won't work? (besides being full serpentine I'm sure)
  11. 83ZZ502_Jimmy
    Feb 7, 2001
    3,103
    Richmond, VA
    Yes the A/C does go to the intake.
    A 96 Setup could/might work, but then, the A/C compressor is different. If his A/C is working now, he would have to do a full evacuate and recharge to convert to the newer compressor. Plus then the lines may not work.
    It could get expensive quickly.
    John
  12. dyeager535
    26,979
    So, yet another reason Vortec heads suck compared to Pro-Toplines or anyone elses. /forums/images/graemlins/smile.gif
    There HAS to be a decent fix for this though realistically, Vortec heads have gained so much popularity to retrofit, people still must want AC...
  13. 83ZZ502_Jimmy
    Feb 7, 2001
    3,103
    Richmond, VA
    There has to be a way. Maybe through some creative bending or some new supports/brackets to use as bracing like original.
    GM does have a fix for the problem however. Their solution is to offer a serpentine conversion kit. With and without A/C. This kit comes with everything including the water pump, alt, ps, and AC. But to the tune of 750 bucks. /forums/images/graemlins/yikes.gif /forums/images/graemlins/smile.gif
    So we shall see if it can be made to work...
    John
  14. dyeager535
    26,979
    The problem, as I found out with the '88 coil/EGR solenoid bracket I have, is that even if you can bend the brackets to the right angle, the bolts are a different distance apart. /forums/images/graemlins/mad.gif
    IIRC, it was at just such a distance that the bracket I had wasn't long enough, so I couldn't elongate the hole.
    A new bracket shouldn't be that difficult to come up with, perhaps on Vortec carbed intakes they have thought to cast in a few drilled/tapped holes for this idea?
  15. 83ZZ502_Jimmy
    Feb 7, 2001
    3,103
    Richmond, VA
    On the edelbrock carb'd intake I used on a previous project, it did not have any provisions for such a problem. Maybe the GM one will have an area cast and tapped for that.
    John
  16. sandracer799
    Feb 10, 2004
    834
    Richmond,Virginia
    Thanks for all the help guys i will try all of your suggestions and see what happens. /forums/images/graemlins/thumb.gif
    Josh
  17. dyeager535
    26,979
    You already have the heads or?
    If not, I'd highly suggest against them, IMHO.
