pullin of steering arm?
Discussion in 'The Garage' started by broncoman6524, Oct 29, 2006.
  1. broncoman6524
    broncoman6524 1/2 ton status
    Oct 31, 2005
    2,469
    chuluota Fl
    the one on top of the 10b knuckles. ive got a truck with 6" lift on it the front axle is out and im trying to get the arm off the new trucks axle so i can put it on mine. ive already chained the axle to a tree and snatched ont eh arm with my truck it didnt budge. yes i removed the bolts. any ideas?
  2. Brodie
    Brodie 1/2 ton status
    Mar 20, 2006
    255
    Puyallup, WA
    Use at least a 2 lbs hammer and swing for the numbers on the top of the arm. If it still dosen't move after a few smacks, use some WD-40 on the conical washers and give it a few minutes. Then whack it again. Repeat until the washers wiggle out, or your arm cramps up.
  3. dontoe
    May 7, 2004
    9,070
    Hickory, N.C.
    What he said, plus hold a propane torch on it till it's good and hot! Smack repeatedly!!! :D
  4. MattK
    MattK 1/2 ton status
    Jan 12, 2005
    1,713
    Dallas, TX
    pb blaster and lots of whacking like said. the long it soaks in pb, the better.
    the best place to hit it is downward, about halfway around the curve.
  5. Moody
    Moody 1/2 ton status
    Aug 4, 2005
    232
    Yakima, WA
    Soak real good in PB or WD-40 and take an impact socket just slightly larger than the washer and whack right on top of it once or twice. That should loosen it up enough to get something to grab hold of it.
  6. 79k20350
    79k20350 3/4 ton status
    Nov 22, 2004
    7,757
    Ct
    its off the truck you said? find the biggest sledge you can and whack away...!:D
  7. CB77GMC
    CB77GMC 1/2 ton status GMOTM Winner
    May 6, 2005
    771
    Heath Springs, SC
    20lb sledge and some PB Blaster :D
  8. beater_k20
    beater_k20 Banned
    Dec 9, 2003
    10,276
    Elkhart, IN
    just be careful or you'll end up with one of these...
  9. MattK
    Jan 12, 2005
    1,713
    Dallas, TX
    lol how did you manage a hole that large?
  10. beater_k20
    beater_k20 Banned
    Dec 9, 2003
    10,276
    Elkhart, IN
    what you cant see is the hammer that i was actually using. about 4 times the size of the orange one in the pic. :D and i moved the 44 after i knocked the hole in the floor, so you cant see that either. its on the dolly in the upper left corner of the pic.
  11. Brodie
    Mar 20, 2006
    255
    Puyallup, WA
    Just treat it like it owes you money and it'll come right off.
  12. 85mudblazin
    85mudblazin 1/2 ton status
    Mar 26, 2004
    3,951
    Austin,TX
    Jeez do people not know how to search these days?? This is covered atleast once a week...........
  13. beater_k20
    beater_k20 Banned
    Dec 9, 2003
    10,276
    Elkhart, IN
    people cant search if they dont pony up the $25 and get one of these... [​IMG]
  14. chrisb420
    chrisb420 1/2 ton status
    Aug 6, 2004
    652
    Binghamton, NY
    im thinking if you chained the axle to a tree and tried to pull it off with your truck that you just made it that much tighter to get off. The conical washers tighten the more they forced upwards, so hit it down and from the side with a big arse sledgehammer and it should come off. and if you do use heat try not to get the ball joint area to hot.
  15. 85mudblazin
    Mar 26, 2004
    3,951
    Austin,TX
    Great CK5 has started that also. Its stupid that Pirate did it now there is a bunch of BS over there.
  16. beater_k20
    beater_k20 Banned
    Dec 9, 2003
    10,276
    Elkhart, IN
    "started" that? its been like that for a long time.
  17. 85mudblazin
    Mar 26, 2004
    3,951
    Austin,TX
    Prolly has, I havent been a non-paying member.
  18. UseYourBlinker
    UseYourBlinker 1 ton status
    Jun 7, 2000
    11,117
  19. muddybuddy
    muddybuddy 3/4 ton status
    Jan 29, 2004
    8,933
    Fairfax Station VA
    i didnt know that either:doah:
    i think they are going to do that, then they need a FAQ thread with links to all the questions like this
  20. goldwing2000
    goldwing2000 Guest
    Agreed!! :saweet:
