pullin on heavy braking? WTH
Discussion in 'The Garage' started by broncoman6524, Apr 3, 2006.
  1. broncoman6524
    broncoman6524 1/2 ton status
    Oct 31, 2005
    2,469
    chuluota Fl
    When i step on the brakes hard the truck wants to pull left and right. Could this be a sticking or loose brake, or a bad steering stabalizer. Its been drivign me crazy and makes my passengers freak out anytime i need to brake hard. :D
    jus wondering
  2. 1985_K5_Silverado
    1985_K5_Silverado 1/2 ton status
    Dec 21, 2005
    984
    Corn Country
  3. Chaddy
    Chaddy 1/2 ton status GMOTM Winner
    May 23, 2005
    4,110
    Salt Lake City,Utah
    sticky caliper and or warped rotor
  4. JDNobodi
    JDNobodi 1/2 ton status Premium Member
    Oct 9, 2002
    3,002
    193
    Santa Maria, CA
    A plugged brake hose could cause it to pull to one side. Try bleeding the caliper on the opposite side that is pulling. If you have a hard time getting fluid though the bleeder compare to the side that pulling-then you may have a plugged line.
  5. MattK
    MattK 1/2 ton status
    Jan 12, 2005
    1,713
    Dallas, TX
    yeah bleed first. a while back i had a pull, it was from a failiing caliper. when i jacked up the front end and applied a slight amount of brake pressure, the failed side's tire was easier to spin. after pressure was takin off the pedal, the failed side was harder to spin.
  6. mouse
    mouse 1/2 ton status
    Nov 10, 2003
    1,448
    Great Falls Mt
    If you have a plugged line, the failed side could be eaiser to spin (no brakes).
  7. JDNobodi
    Oct 9, 2002
    3,002
    193
    Santa Maria, CA
    Did I say "spin"? No. I meant fluid would have a hard time trying to go though a plugged line, hence, a plugged line would not let any pressure reach the caliper and the wheel would be easier to spin.
  8. mouse
    Nov 10, 2003
    1,448
    Great Falls Mt
    Just re-stating for clarification. Sometimes it seems the side that has brakes is the side that has the problem, and its not apparent that it is really the other side.
  9. azblazer
    azblazer 1/2 ton status Premium Member
    Jul 20, 2003
    695
    15
    Grand Junction, Co.
    I have had this problem before. The cure for me was to ditch the cheap as front pads and install genuine gm pads...problem solved. Really burns ya when you think its a caliper and it switches sides...
    DW
  10. jones
    jones 1/2 ton status
    May 17, 2004
    379
    IONIA,MI USA
    mine has been doing that lately,also.i tore it down to assess the situation,and that's when i noticed that i was missing a caliper bolt(wtf?)i was thinking someone was sabotaging my stuff,but when i tried to put in another bolt,i found that th threads were stripped in the backing plate and the new bolt wouldn't thread into it.it must have fallen out eventually after hitting the chatter bumps on the dirt roads all the time.hope it helps.good luck!
