Pulling 14 bolt axle - emergency brake cable removal
Discussion in 'The Garage' started by Yukon Jack, Jun 20, 2004.
  1. Yukon Jack
    Yukon Jack 1/2 ton status
    Jul 25, 2002
    1,984
    Rose Hill, KS
    I'm pulling a 14 bolt out of a 78 3/4 ton. I have everything disconnected except the emergency brake cable. How do I diconnect it so I can pull the axle out from under the frame? Do I remove the two bolts on the back side of the drums where the cable feeds in and disconnect there or do I some how disconnect the cable where it is attached to the frame? I don't see how I disconnect it from the frame, if that is the place to do it from.
  2. heavy4x4
    heavy4x4 1/2 ton status
    Aug 28, 2002
    3,270
    Delafield, Wisconsin
    If you want to disconnect it from the axle, you remove the two bolts holding it to the backing plate and also free the end from the arm inside the drum...then it will pull out. You will have to pull off the drums in order to disconnect the cable at the axle. Not sure about the frame end. The 14 bolt I got had the e-brake cables cut off. /forums/images/graemlins/thinking.gif
    But, if it's anything like my 10 bolt's e-brake cables, there will be connections somewhere along the line that just need to be pried open a bit and the cable end will come out.
  3. Yukon Jack
    Jul 25, 2002
    1,984
    Rose Hill, KS
    Went ahead and just ground off the rivets holding the cables to the frame.
  4. heavy4x4
    Aug 28, 2002
    3,270
    That will work too. /forums/images/graemlins/grin.gif
