Pulling a 700r4
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by FergsK5, Aug 26, 2002.
  1. FergsK5
    FergsK5 Registered Member
    May 5, 2002
    20
    Moncks Corner, SC
    I am pulling my 700r4 outta my 84 k5. Any tips or advice? DO I have to remove the crossover pipe for the exhaust? Any other ideas? Thanks
  2. wayne
    wayne 3/4 ton status
    Feb 1, 2001
    6,178
    Carlisle, Pa
    I did mine on a lift with a trans jack. I did not have to remove the exhaust. If you don't have access to a lift make sure you have a tall enough jack with some sort of trans adapter for it. We clamped to the crossmember which made it easier but I think the adapters usually go under the trans pan. If that is the case you might have to remove the crossover pipe.
  3. Calclips
    Calclips 1/2 ton status
    Apr 4, 2001
    1,005
    Swartz Creek, Michigan/Flint while in school
    usually if you have a crossover pipe, you have to remove it. You can try to floss and fly that baby in and out arround the crossmember, but it would probably make everything a lot easier if you just dropped the crossover.
