Pulling Brakes
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by pr1aw, Aug 18, 2002.
  1. pr1aw
    pr1aw 1/2 ton status
    Sep 17, 2000
    144
    San Diego CA
    I replaced the passenger and driverside calipers and brake shoes because my Blazer was pulling to the driver side. I also checked the bearing adjustment on both sides also while I had it in the air. Well its still pulling to the driver side when the brakes are applied. I also bled the brakes with a vaccum pump. Any ideas?
  2. ftn96
    ftn96 1/2 ton status
    Sep 26, 2000
    3,238
    Nashville Tn
    If it is turning the wheel its the front, if it feels like the whole truck is pulling or veering then you need to check the back. If one is grabbing better than the other you will get this. Also, maybe try purging all the old fluid out. Could have some cotaminants blocking up the propotioning valve. /forums/images/icons/wink.gif
  3. BigBurban350
    BigBurban350 1/2 ton status
    Jun 9, 2002
    711
    Michigan
    BRAKE LINES ARE WORN OUT! /forums/images/icons/shocked.gif
  4. YtseJam
    YtseJam 1/2 ton status
    May 19, 2002
    147
    CT USA
    Replace the brake hoses. That will solve your problem. /forums/images/icons/laugh.gif
  5. ftn96
    Sep 26, 2000
    3,238
    Nashville Tn
    Replaced all mine with the lift kit install and I still have the problem. Somedays it wont pull at all till they get nice and hot, then other days the start pulling bout the same time the computer goes in closed loop. So it has to do with friction/heat at some point in the equation or since its inconsistant it points more towards to the fluid having "particulate contamination". **/forums/images/icons/grin.gif Throw a party <- he said a big word.
  6. pr1aw
    Sep 17, 2000
    144
    San Diego CA
    Think I solved th problem, I have a bent spring near the rear eye bolt on the passenger side.
