Pulling Carrier and gears? ASAP
Discussion in 'The Garage' started by Hossbaby50, Jul 19, 2004.
  1. Hossbaby50
    Hossbaby50 3/4 ton status
    Sep 1, 2001
    8,972
    Peoria, AZ
    I am about to pull an open carrier out of a 10 bolt front and need to know what exactly to do.
    Give me a quick run down on how to do it in order so I don't F it up.
    Harley
  2. pauly383
    Jul 22, 2001
    16,217
    Mesa , Arizona USA
    You should be able to take the caps off ( put them back where they came from ) and it will come out , maybe pry it a little , but not by the ring gear . The broken gov loc came out with no prying . TJ's front came out with little drama . So did his open rear 10 bolt when he pirated the carrier for someone . /forums/images/graemlins/k5.gif
    So its remove outers and spindles
    pull shafts
    remove caps
    pry out gently
  3. Hossbaby50
    Sep 1, 2001
    8,972
    Peoria, AZ
    Sweet, I talked to Matt earlier and he said the same thing. I already popped out the axles and outers and will pop the carrier for TJ tomorrow. I got ahold of him an he needs it. Thanks
    Harley
