pulling diesel drivetrain, messy !
Discussion in '1982-Present GM Diesel' started by R72K5, Aug 28, 2004.
  1. R72K5
    R72K5 Banned
    Mar 5, 2001
    central IL
    wish i had a digicam to show but damn i was white instead of black for a while today, several times, pulling that 5.7L diesle and th375 out,.
    way messier drivetrain than akk the others int he past, and ive pulled a ton of drivetrains now!
    i learned today that oldsmobile 350 diesel are only attached to the mounts by two bolts both sides, 5/8" head into the sides of the block, instead of three 3/8" diameter bolts.
    i learned a few other things today, but nothing spectacular really.
    the th350 in it is a 10 bolt bellhousing dual pattern and has an large X indientated into the pan,
    so i assume th375
  2. imiceman44
    imiceman44 1 ton status
    Aug 5, 2002
    Sacramento, CA
    Are you sure it's a th350?
    All the olds 350 diesels I have seen had the Th400 BOP pattern.
