Pulling engine and transmission tips??
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by Tonyraca, Nov 23, 2005.
  1. Tonyraca
    Tonyraca Registered Member
    Sep 28, 2000
    87
    San Jose, CA
    I am planning on pulling my SB350 and TH350 in one piece and leave the trasfer case mounted. It looks like the transmission is not really attached to my NP203 transfer case. I am sure that I will find out soon, but I wanted to know if anyone has any tips. I already removed my steering pump and radiator. It looks like removing the starter will help too, but I havn't done that yet. I am sure that I will bust a few knuckles, but so far I have been doing everything the hard way. I hope you guys have some good tips. Thanks in advance!!
  2. roadnotca
    roadnotca 3/4 ton status
    Sep 16, 2005
    5,433
    Redondo Beach, CA
    Tony, read a book, any book. It will save a lot of wasted work and grief.(spelling?):D
  3. mouse
    mouse 1/2 ton status
    Nov 10, 2003
    1,448
    Great Falls Mt
    Make sure you disconnect the exhaust manifolds, all coolant hoses, cables and wires. One I forget now and then is the ground strap on the rear of the passenger side head.
    There was never a divorced 203 setup (IIRC). I'm betting its attached. They weigh a lot and will make pulling everything out very difficult. I would recommend disconnecting the trans/TC combo, pull the engine, then drop the trans/TC.
    If you really want to take it all out at once, be sure to have the rad out, and a couple of friends to help "ease" it out from under the hood.
  4. roadnotca
    Sep 16, 2005
    5,433
    Redondo Beach, CA
    Exactly, what he said. :D
  5. Muddytazz
    Muddytazz 1 ton status
    Jun 30, 2002
    20,073
    Salem, Or.
    Remove the front clip, makes pulling everything one hell of a lot easier
  6. sweetk30
    Nov 1, 2004
    25,548
    543
    horseheads , ny 14845
    with 203 tcase you need to remove the tcase to remove the adaptor. sorry.
  7. Tonyraca
    Sep 28, 2000
    87
    San Jose, CA
    Yea. I have the chiltons manual and it says that for a 4 wheel drive setup that you can't remove the engine and transmission together. Since my main goal is just to get the engine out, I will just follow the instructions in the manual which seem to be pretty straight forward. Figured I would check it out with the experts first.
  8. roadnotca
    Sep 16, 2005
    5,433
    Redondo Beach, CA
    Yeah, I was used to cars were you do pull eng/trans together, but I pulled the trans/T-case out and it was the right choice. Eng comes out (by itself; wouldn't that be sweet?) in three weeks, plus T-case clocking but they will be separate operations, you bet.
  9. Leper
    Leper 1/2 ton status
    Feb 18, 2005
    4,437
    Dallas Baby!!!!
    Disconnect the trans from the engine. Take the hood off.
  10. Tonyraca
    Sep 28, 2000
    87
    San Jose, CA
    Well I got the engine out in about 3 hours with a friend helping. I took out the engine and left the transmission in. It actually went pretty well. Some of those bolts are a real pain to get to though. Now the real fun begins.
  11. hidesertwheelin
    hidesertwheelin 1/2 ton status Premium Member
    Nov 13, 2004
    782
    4
    Hesperia, CA
    Ya what he said!
  12. roadnotca
    Sep 16, 2005
    5,433
    Redondo Beach, CA
    Its so much hurt, it funs.:haha:
  13. ProJunkRacing
    ProJunkRacing 1/2 ton status
    Jun 20, 2005
    1,229
    FrankFort IL
    by far the easiest way to do things all at once
