pulling engine codes 24 and 44
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by Jishory, Jan 7, 2006.
  1. Jishory
    Jishory 1/2 ton status
    Jan 8, 2002
    1,367
    Palmdale, CA
    vss and lean exhaust...
    when i did the manual swap on my truck i had to lose the mech speedo because the drivetrain was from an 89 k30 and when i swapped my 305 for a 350 i put in the computer from an 87 suburban in, i went mudding the other day and on the way home my engine was running like crap, felt like it was making no power, when i put my foot in it it revs high then goes back down to idle speed pretty rapidly, with a manual my truck looks like coupe deville in compton hopping around. i never had an issue until recently so i dont understand where the vss could be an issue. vacuum leak? fuel filter?
  2. Thunder
    Thunder 3/4 ton status
    Jul 20, 2000
    8,946
    Northeast Nevada
    44 is lean exhaust. Prolly having fuel delivery problems Check/change fuel filter first. Maby fuel pump is going out. Maby bad MAF sensor.
    No VSS wont cause a whole lot of problems. just usually a bad idle or stalling
  3. Jishory
    Jan 8, 2002
    1,367
    Palmdale, CA
    it was the fuel filter, THANKS! :D
  4. onlychevy6
    onlychevy6 1/2 ton status
    Mar 29, 2003
    1,293
    Hockley, Texas
    funny that you have those codes i have he same thing on my 88 1 ton 454 truck. sad thing is it is not the fuel filter.:mad:
  5. K5Greek
    K5Greek 1/2 ton status
    Nov 25, 2005
    2,054
    Vineland, NJ
    im pretty sure when i had a 44 it was the o2 sensor..but im not positive.
