Pulling engine
Discussion in 'The Garage' started by kerwinq, Mar 12, 2004.
  1. kerwinq
    kerwinq Registered Member
    Jan 25, 2004
    20
    Boise, Id
    I am pulling the engine out of the 75 4x4 this weekend, what is the best way to do this. Pull the engine and trans together or pull the engine seperate. I have not done this in a 4X4 so not sure. The truck will be sitting without an engine for a short time so do I need to support the trans or tc until I re-install?
    Thanks for the help, Kerwin
  2. big83chevy4x4
    big83chevy4x4 3/4 ton status
    Mar 22, 2002
    6,587
    Sheridan, Michigan
    if you are pulling just the engine, then just ull the engine. its more trouble puttingthem back in together. i normallay have a jack under the tranny pan to keep it from falling to far
  3. BlazerGuy
    BlazerGuy 3/4 ton status
    Apr 20, 2000
    9,206
    abcde
    Might to easier to pull both since you can leave the t-case on it's mount. I would take off the front clip first...makes it much easier, and it doesn't take that long...
  4. Smitty
    Smitty 1/2 ton status
    Sep 1, 2000
    999
    Crestview, FL
    If you leave the trans in the truck you need to support it. If it will be a while you might want to rig a brace for the front of the trans. I cut a piece of wood and set it across the frame rails then drilled a couple of holes in it to match the trans case. It does a good job of holding the trans up and I can push the truck around if I need the space.
