Pulling hard to the left
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by Redline, Oct 30, 2001.
  1. Redline
    Redline Registered Member
    Sep 30, 2001
    6
    NJ
    Went up 2.5" on my 86 Blazer (Rancho). Dropped the transfer case 1" to stop the drivetrain vibration. Truck drives and stops strait with no sway or wander.
    Here is the problem...
    In the morning, it starts to pull to the left a little. Sometime after, the truck jerks hard to the left.
    This happens within the first 15min of driving and then goes away entirely. Happened 3 days now.
    I have a stock steering stabilizer and it happens on highway roads. Could something be binding?
    Appreciate any help
  2. dysphemism
    dysphemism 1/2 ton status
    Oct 26, 2001
    667
    Fremont, CA
    Check out your inner bearings and ball joints. My truck would pull harshly to the right during heavy breaking. It turned out to be that my right inner bearings were totally destroyed.
  3. Stickseler
    Stickseler 3/4 ton status
    Mar 23, 2001
    6,503
    Northern Virginia
    Mine pulled hard right and it had a seized caliper and bad ball joints. It would also pull both ways depending on which way I turned last...that turned out to be the steering stabilizer
    I'm not late im on Central Standard Time
  4. 83ZZ502_Jimmy
    83ZZ502_Jimmy 1/2 ton status
    Feb 7, 2001
    3,103
    Richmond, VA
    I would check the same things above. Calipers, bearing and ball joints can do this.
    John
    <font color=blue>"When all else fails, read the instructions, or get a bigger hammer"</font color=blue>
  5. Redline
    Sep 30, 2001
    6
    NJ
    Will check out this weekend. Thanks for the ideas..
