Pulling Ignition tumbler
Discussion in 'The Garage' started by 74kay5, Dec 15, 2006.
  1. 74kay5
    74kay5 1/2 ton status
    Oct 30, 2003
    486
    San Jose CA
    I have an 85K5 with a bad ignition. I was looking at it today and I have no idea how to get it out. Do you have to take apart the entire steering column?
  2. original balzer
    original balzer 1/2 ton status
    Nov 17, 2004
    4,660
    roosevelt utah
    you have to take most of the stuff behind the steering wheel out witch can be a pain in the a**. you have to compress the lock ring and take a clip off the steering shaft and not let it fly up and hit you in the nose. takeing it off is fairly easy but putting it back on is a differnt story. they have a tool for it but i couldnt get it to work. then its simple pin that holds it in pull the pin and it slides out newer could be a little differnt last one i took apart was a 74 olds
    balzer
    PS sorry if i didnt help much and my grammar is crap i have had a few beers tonigh
  3. 74kay5
    Oct 30, 2003
    486
    San Jose CA
    So pull the steering wheel and all the stuff for the tumbler is behind it?
  4. Slapperbar
    Slapperbar Retired Navy NDT Examiner Premium Member
    Nov 29, 2005
    2,747
    3
    Harrison City, Pennsylvania
    Pull the wheel and lock ring and turn signal B.S. and it should be right there.
  5. Slapperbar
    Nov 29, 2005
    2,747
    3
    Some have just a #2 philips holding them in.
  6. beater_k20
    beater_k20 Banned
    Dec 9, 2003
    10,276
    Elkhart, IN
    but its behind all that crap none the less...
  7. surpip
    surpip 1 ton status
    Apr 7, 2004
    10,877
    sacramento ca
    and the directions with the new tumbler will explain it pretty well, i just did mine not to long ago
  8. 74kay5
    Oct 30, 2003
    486
    San Jose CA
    OK here's the next question, anyone have one?
  9. BKinzey
    BKinzey 1/2 ton status
    Jan 13, 2006
    3,145
    Hollywierd, CA
    Gee, they just use a slide hammer in the movies:D :eek1:
    I think new are fairly cheap, check eBay or your fav on-line auto;)
  10. Slapperbar
    Nov 29, 2005
    2,747
    3
  11. Slapperbar
    Nov 29, 2005
    2,747
    3
    PN. LC31 $12.44 at Advance. They have them on the shelf.
  12. bear76
    bear76 1/2 ton status
    Oct 16, 2005
    1,065
    here
    What is the name or part number of the tool to remove the lock ring? Or, how have others removed it?
  13. Slapperbar
    Nov 29, 2005
    2,747
    3
  14. Slapperbar
    Nov 29, 2005
    2,747
    3
    Advance should have them on the shelf. So do most other parts houses. Should be under $15.
