Pulling the drums off of a 14FF
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by 8_YOUR_H2, Jul 9, 2000.
  1. 8_YOUR_H2
    8_YOUR_H2 1/2 ton status
    Feb 20, 2000
    2,663
    Iowa
    I am overhauling my 14FF and I cant get the drums off. I rember reading where there is a key that needs to be take out and a special nut taken off. However Chiltons guide says to beat on it with a rubber mallett and it will pop right off. I am sure there is a nut there that needs to be taken off.
    Brent
  2. Balou
    Balou 1/2 ton status
    Apr 15, 2000
    207
    back to Germany
    Never ever saw a drum with a nut outside.
    What you mean maybe is a little hole backside of the drum you just open to get a screw-driver in to remove the breakpads from the drum.
    Not sure the 14bolt is equipped with this, but it is something you can do easily by yourself for easier drum removal next time.
    Balou
    "Size DOES matter!!!", said the girl last night.
    http://www.balou.coloradok5.com
  3. CK5
    May 19, 1999
    21,627
    704
    CO
    After the axle shafts are removed you will need a special 6 prong tool to get the retaining nuts off, you can get one at most auto parts store. There will be a inner and outer one, after you remove the retaining nuts the hub/drum will slide off. As you pull the nuts and washers off, set them aside making note of how they go back in.
    Steve
  4. titanic
    titanic 1/2 ton status
    Mar 27, 2000
    498
    north alabama(huntsville)
    The drums on my 14 bolts(3) were attached to the hub and you can't get them off until you remove the axle shaft and remove the hub.
  5. 8_YOUR_H2
    Feb 20, 2000
    2,663
    Iowa
    No I took the axels out and it is a special looking nut inside of the drum...I read in a 4 wheeler when they did a disc brake swap where there was a key in there and a special socket is needed to get the drum off...
  6. 8_YOUR_H2
    Feb 20, 2000
    2,663
    Iowa
    Hey that was easy! Had to buy the tool 11$ no biggie!
    Thanks again
    Brent
  7. Balou
    Apr 15, 2000
    207
    back to Germany
    Hhhhmmmmm, funny US stuff...
    What about 12bolt, will have to pull the drum soon???
    Balou
  8. Blazer79
    Blazer79 1/2 ton status
    1,816
    Guatemala, Central America
    The 12 bolts have nothing to hold them. The only problem you could find is if the break pads are adjusted too tight. You just turn the adjusting nut until the pads aren't breaking anymore and tap it with a mallet. Piece of cake.
    <font color=blue>//////
    http://blazer79.coloradok5.com
    </font color=blue>[​IMG]
