Pulling tranny and need to keep things from spinning
Discussion in 'The Garage' started by 74kay5, Mar 31, 2006.
  1. 74kay5
    74kay5 1/2 ton status
    Oct 30, 2003
    486
    San Jose CA
    Anybody know any tricks if your pulling a transmission by yourself to keep everything spinning when loosening or tightening the flexplate to torque converter bolts? I tried putting a large socket and wrench on the front balancer bolt on the front of the crank and a large breaker bar but it just slips off with every try I make. I know there's a tool that has teeth and holds the flex plate at the bottom by the teeth but again, you need 2 people.
  2. onetonbb74
    onetonbb74 1/2 ton status
    Dec 1, 2005
    2,083
    Campbell, CA
    if you need help holding the crank, i live in sj and can help. Otherwise, i use a skrewdriver and put it inbetween the engine oil pan and a random hole in the flexplate then turn until it stays there.
  3. 74kay5
    Oct 30, 2003
    486
    San Jose CA
    Thanks for the offer, but I moved to the north bay. I never thought of that, I'll try it, thanks.
  4. big83chevy4x4
    big83chevy4x4 3/4 ton status
    Mar 22, 2002
    6,587
    Sheridan, Michigan
    the easiest way i have found, turn the flexplate so the bolt is close to the bottom. put the wrench on it so that is sticks to the left of the truck, then yank straight down. it puts more force on the bolt and is harder to turn the motor over.
  5. goldwing2000
    goldwing2000 Guest
    That method works. If it's still too tight (it shouldn't be) use a combination of that and onetonbb74's method. I would put the screwdriver on the ring gear and brace it against the bellhousing, though.
  6. HarryH3
    HarryH3 1 ton status Author
    May 31, 2000
    10,384
    Georgetown, TX
    I've used the "try to jam a screwdriver in there" method in the past. I finally broke down and spent the $10 for the correct tool for holding the flywheel/flexplate in place. It makes those jobs SO much easier. It was well worth the money. :cool1:
  7. jk3078
    jk3078 1/2 ton status
    Nov 12, 2005
    374
    Moyie Springs Id.
    Allways worked for me.
  8. mo
    mo 1/2 ton status
    Jun 29, 2004
    542
    Folsom, CA
    not part of the question, but when installing or pulling tranny and t-case combo by yourself, a tranny jack is very very nice to have a round. i stuck it under the furniture dolly i was wheeling the tranny/t-case on and just jacked up the whole thing, made life much easier, and safer too. Almost killed myself taking it down before I got the tranny jack...
  9. 74kay5
    Oct 30, 2003
    486
    San Jose CA
    where did you get it? I asked around my local shops and they are so retarded they don't even know what I'm talking about. They just give me that look of bewilderment when I start talking about pulling a transmission.
  10. HarryH3
    May 31, 2000
    10,384
    Georgetown, TX
  11. garlicbreath
    garlicbreath 1/2 ton status
    May 17, 2003
    1,136
    Denver
    I must be confused. My torque converter bolts have nuts on the back. 2 9/16 wrenches is all I need. Does your torque converter have threads in it?
  12. big83chevy4x4
    Mar 22, 2002
    6,587
    Sheridan, Michigan
    th350s and most th400s have a tab that uses a bolt and a nut, the 700r4s and a few th400 converters have a threaded part welded to the converter, no nut.
  13. stockk5
    Apr 13, 2004
    2,037
    73
    Cromwell, CT
    impact it off.. i just took my 9/16th closed box and put it over the bolt.. then just hammered on the wrench... this way it loosens the bolt w/ out having the whole thing spin.. worked great for me.
  14. R77K10
    R77K10 Banned
    Mar 15, 2006
    564
    Lincoln IL
    i always use a BF flathead screwdriver or a tire iron,
    but thats rare nowadays since i have one of thos enice flywheel teeth grabber handle tools exact same as the northern tool one, ours is red handled we got it from parts plus auto parts store years before they shut their doors here
    we use it all the time sometimes as much as everyday
    good luck
  15. muscle
    muscle 1/2 ton status
    May 28, 2000
    408
    Show Low, AZ
    Ive never had this problen on a TH350 or 400. I just put on a heavy glove on on hand to hold the ring gear with and with a wrench in the other hand, yank that bolt loose. :D
  16. 74kay5
    Oct 30, 2003
    486
    San Jose CA
    just ordered it from northern tool, at 7.99 I couldn't afford to not buy it. I'll just wait until it comes in to pull the tranny. It's been raining non-stop for weeks anyway.
