Pulling trans and t-case
Discussion in 'The Garage' started by orangeGMC, Mar 7, 2005.
  1. orangeGMC
    orangeGMC 1/2 ton status
    Dec 26, 2004
    184
    Connecticut
    I am going to pull my transmission and transfer case out in order to replace my transmission. Has anybody pulled them out together, as one assembly? How did you do it? Any recommendations, as in the easiest way?
    By the way it is a TH350/203 combo.
  2. sweetk30
    Nov 1, 2004
    25,537
    536
    horseheads , ny 14845
    friend with shop and lift . also a tranny jack. and that iron 203 will be best taken by its self. then tranny
  3. Jeromy Gibson
    Jeromy Gibson 1/2 ton status
    Apr 17, 2003
    127
    Amarillo Texas
    Cherry picker through the door works for me, I can have my 465/205 out in about 20 mins now.
  4. RustBuket
    RustBuket 1/2 ton status
    Feb 21, 2003
    1,618
    Saskatchewan, Canada
    I took off my TH350 and NP208 off together by myself using only a floor jack and a stack of wood. I put the floor jack underneath the trannt pan with a peice of wood to spread the load and a a pile of wood under the t-case. Then you drop the tranny down a bit, take a peice out from under the t-case, and repeat. Its slow but it gets the job done. A good way to do it if you had a removable tranny tunnel would be to get an engine hoist in from above through the tunnel hole and put a strap around both. you have to remove the shifter, carpet and seats for this though. Best way would be on a lift with a tranny jack but we don't all have that as an option. Also, the 203 is a heavy pig.
  5. pvfjr
    pvfjr 1/2 ton status
    Feb 10, 2004
    2,425
    Oakridge, OR
    Been there, done that.
    The only reason to pull them together is if you don't plan on separating them. Since you're replacing the tranny, I would do it one at a time.
  6. orangeGMC
    Dec 26, 2004
    184
    Connecticut
    I made my trans tunnel a bolt on one. I don't have a lift. I do have a floor jack with the transmission adapter.
  7. sickquad
    sickquad 1/2 ton status
    Jul 23, 2003
    785
    Ma
    Throw the NP203 in the trash while you're at it.
  8. orangeGMC
    Dec 26, 2004
    184
    Connecticut
    I am keeping my 203 for when I do the doubler.
