pulls to the right
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by Doug M, Nov 14, 2002.
  1. Doug M
    Doug M Registered Member
    Nov 8, 2002
    39
    Houston
    It has always done this. Before the 2.5" lift, 33" tires, new wheel bearings, steering box, all new brakes including front calipers and hoses and rear slave cylinders, front end alignment, four wheel alignment including frame straightening, tie rod ends and new drag link. All this has been done in an attempt to correct the problem. I have driven on the wrong side of the road and it still pulls to the right. The only things I have not done are the steering knuckles and the front axle u-joints. Could either of these two items cause this?
    Any suggestions are greatly appreciated. /forums/images/graemlins/1zhelp.gif
  2. 90K5
    90K5 1/2 ton status
    Jun 1, 2000
    3,719
    Lubbock, TX
    how are your tires worn?
  3. Muley
    Muley 1/2 ton status
    Sep 26, 2002
    364
    Eagle Mountain, UT
    Also check tire pressure. Even a little uneven will show up.
  4. 90K5
    90K5 1/2 ton status
    Jun 1, 2000
    3,719
    Lubbock, TX
    Also maybe somethinjg is wrong with your front end, like a few bad ball joints tha tare messing up the way it is tracking, or the swayabr bolted on only one one side...lots of things could cause it if you start thinking about it...
  5. Gary 86 K5
    Gary 86 K5 1/2 ton status
    Oct 7, 2002
    204
    Mentor, OH
    have you tried swapping the front tires side to side?
  6. Doug M
    Nov 8, 2002
    39
    Houston
    Thanks for all the replies. The tires are wearing evenly, outside edges are also even. Tires are rotated routinely. PSI is checked and adjusted on a regular basis.
    I read in a previous post the axle u-joints could cause this? It's not full time, hubs are unlocked unless needed.
    Dreading going into the ball joints but might as well - done almost everything else! /forums/images/graemlins/rolleyes.gif /forums/images/graemlins/tongue.gif
