Pulsating lights
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by 89K5guy, Sep 2, 2006.
  1. 89K5guy
    89K5guy 1/2 ton status
    Jul 11, 2005
    174
    Ohio
    I asked this question a few months ago with almost no results:confused: My lights (all of them)pulsate,flicker ,whatever you want to call it as soon as I pull them on,whether full headlights or just parking lights.The factory volt gage and a handheld volt meter both show between 13 and 14 volts with engine running.
    Could it be that the alternator isn't supplying enuff amps and causing the pulsating/flickering effect?The alternator looks old and is probably stock or is a replacement with a low amp rating.Any advice would be greatly appreciated.:bow:
  2. cbbr
    Jul 17, 2004
    14,681
    High velocity, Low altitude
    Take the alternator to Autozone. They will test it for free. You will get more hits on a question like this in the Garage forum.
  3. 1985_K5_Silverado
    1985_K5_Silverado 1/2 ton status
    Dec 21, 2005
    984
    Corn Country
    All of them, head/tail/parking/marker/dome/courtesy/etc? Does it do it less with the engine off? A corroded/oxidized headlight switch could be the culprit, or even just an unreliably semi-conductive hot lead that feeds the switch (making and breaking the contact rapidly, manifested as flickering, with engine vibration). You could check resistance across the switch or see if there is any difference between voltage in and voltage out.
    If you need to change the switch, it's easy to do, but make sure you disconnect the battery main ground cable first before you start poking around under the switch.
  4. 88sub4x4
    88sub4x4 1/2 ton status
    Sep 22, 2002
    792
    Long Island, NY
    Check the grounding at the alternator, as well as the main grounds off the battery. A simple voltage drop test will reveal if it's OK.
  5. Leper
    Leper 1/2 ton status
    Feb 18, 2005
    4,437
    Dallas Baby!!!!
    Agreed. Check all grounds. If you hit the brake, does the problem stay the same or get better or worse?
  6. 89K5guy
    Jul 11, 2005
    174
    Ohio
    The lights don't pulsate/flicker with the engine OFF.Only when running.:confused:
    Alternator problem???
    I am going to clean and sandpaper all the ground connections to the radiator
    support and from the battery to the engine block.All the grounding straps to the firewall are present.Any other ideas?:confused:
