Purpose of rear interior side panels
Discussion in 'The Garage' started by 84gmcjimmy, Dec 12, 2005.
  1. 84gmcjimmy
    84gmcjimmy 1 ton status
    Dec 3, 2003
    12,838
    B.C. CANADA
    In a blazer or jimmy...the "carpet" interior side panels that go along the sides of the rear of the rig. Are they just cosmetical or do they serve a important role? I threw both my sets out because they were ripped...and I didn't think I need them. I was thinking about hanging the hilift on the brackets, and building light storage cubboards instead of having the panels.
    Comments?
  2. 74757685k5
    74757685k5 1/2 ton status
    Nov 13, 2004
    258
    montana
    looks and insulation prolly.
  3. broncoman6524
    broncoman6524 1/2 ton status
    Oct 31, 2005
    2,469
    chuluota Fl
    pretty much when i got mine it didnt have them. also i think they held speakers too
  4. AZPiNsTrIpEd
    AZPiNsTrIpEd 1/2 ton status
    Jan 24, 2005
    289
    3/4Tonsville
    I ripped mine out and did exactly what you said and mounted my hi lift jack in there. Storage on the other side is a good idea for extra little parts or even holders for spare shafts. I used to use my other side to hold a shovel but had that stolen when my top was off:mad:
  5. Desert Rat
    Desert Rat Fetch the comfy chair
    Oct 19, 2002
    16,250
    3
    Tri-Valley, NorCal
    I pulled mine out and will be Line-X'ing the entire interior. They reduce outside noise, but reduce space too.
  6. HarryH3
    HarryH3 1 ton status Author
    May 31, 2000
    10,384
    Georgetown, TX
    They just make it a lot quieter inside. But don't use those wimpy little brackets that used to hold the side panels in place to hold a Hi Lift jack. Think about what would happen in an accident... Being impaled by a jack coming through the back of the seat would ruin your whole day! :eek1:
  7. Leper
    Leper 1/2 ton status
    Feb 18, 2005
    4,437
    Dallas Baby!!!!
    werd
  8. 84gmcjimmy
    Dec 3, 2003
    12,838
    B.C. CANADA
    I wouldn't just use them, I'd add some more brackets and suport. I just said those brackets to visualize where the jack would go.
    The panels I thought of, like mentioned, would reduce noise and sort of insulate. Oh well i have a heater. And I can always make sheetmetal ones!
    planning to put a roll on/paint on bedliner in one day.
  9. Desert Rat
    Oct 19, 2002
    16,250
    3
    Tri-Valley, NorCal
    I plan on doing a six point rollcage, then Line-x'ing the interior. When that is done, I plan on putting the brackets for the Hi-Lift on the rear part of the roll cage. I also don't want to lose rear speakers so I'm thinking of fabbing up some sheetmetal, or wood boxes with black carpet on them, in a triangular shape and putting them just behind each door on the side against the door pillar and top rail of the rear bed.
  10. Janitorjim8
    Janitorjim8 1/2 ton status
    Feb 21, 2005
    215
    Illinois
    i made new ones out of sheet metal, and behind the rear seat i put hinges, they swing open for storage in there. had them powdercoated black, they look nice.
  11. Desert Rat
    Oct 19, 2002
    16,250
    3
    Tri-Valley, NorCal
  12. bigjbear
    Feb 18, 2000
    13,973
    453
    Marietta GA
    They hold the speakers and ashtrays.
  13. 73k5blazer
    Dec 28, 2001
    4,987
    38
    The Rustbelt
    Cosmetic and noise reduction. That's it.
  14. Robert D
    Robert D 1/2 ton status
    Oct 2, 2005
    261
    Austin, TX
    My '91 K5 came with the barebone rubber mat and no interior panels other than the two doors. The rear is open. There's still ashtrays in the back, however, I have no rear brackets for speakers. My solution is mounting 6x9 speakers in boxes and installing them on the wheel-wells.
  15. 84gmcjimmy
    Dec 3, 2003
    12,838
    B.C. CANADA
    Don't smoke so I don't need the ashtrays, and have boxes for the speakers, so I think I will just forget about the panels. Maybe build some storage comparments with 18ga steel or something. And some storage for parts and hilift.
    Thanks for the help
