push button 4wd
Discussion in 'The Garage' started by madups311, Nov 30, 2003.
  1. madups311
    madups311 Registered Member
    Nov 14, 2001
    72
    VA
    Has anybody tried to put one of the new push button transfer cases behind there 700r4? is it possible? /forums/images/graemlins/ears.gif
  2. MTBLAZER89
    MTBLAZER89 3/4 ton status Premium Member GMOTM Winner
    Aug 14, 2001
    7,272
    236
    Oak Harbor, WA
    Probably not, but why would you want to?? Just wondering
  3. blasterD
    blasterD 1/2 ton status
    May 24, 2003
    410
    Anchorage Alaska
    Mechanically it should bolt right up, but I'm not sure how the wiring works. It may be as easy as hooking up a few toggle switches. It should be just as strong as an np241. One problem would be that all of the push-button transfer cases were drivers side drop. It wouldn't work with a GM solid front axle.
  4. big83chevy4x4
    big83chevy4x4 3/4 ton status
    Mar 22, 2002
    6,587
    Sheridan, Michigan
    you will need a custom adapter. in 96 gm redesigned the case for the 4l60e, removable bellhousing and also the 4wd is a 5 bolt on the tranny instead of a 4 bolt like ours but i don't think that the tcase patern would be the same
