push button Ignition??
Discussion in 'The Garage' started by smprider112, Sep 2, 2004.
  1. smprider112
    smprider112 1/2 ton status
    May 1, 2004
    624
    Beaverton,Oregon
    Ok so my ignition switch is pretty craptastic ( I have to turn it slowly until it triggers the starter...just to start it) So I bought a pushbutton style Im gonna mount on the dash...now my question is how? what wires from the ignition trigger the starter? and how do I get to them? (pull the steering wheel /forums/images/graemlins/dunno.gif) Also Im gonna make this so u have to use the key to turn the igniton on, then just push the button to trigger the starter (so someone cant just hop in it and steal it /forums/images/graemlins/whistling.gif) anyways any help on this would rock /forums/images/graemlins/peace.gif /forums/images/graemlins/thumb.gif
  2. BranndonC
    BranndonC 3/4 ton status
    Mar 18, 2002
    8,591
    Anaheim, Ca
    i'm thinking of push button also, but have a hidden kill switch, or 2 switches, located seperately, eliminate the keys all together.. lol maybe not, but something like that
  3. pauly383
    Jul 22, 2001
    16,217
    Mesa , Arizona USA
    Purple runs to the starter . It needs to momentarily touch red to work . /forums/images/graemlins/k5.gif
  4. big83chevy4x4
    big83chevy4x4 3/4 ton status
    Mar 22, 2002
    6,587
    Sheridan, Michigan
    yep, plus pink needs to touch red for everything else to work and for it to fire up, but thats what the ingnition switch is for /forums/images/graemlins/waytogo.gif
  5. smprider112
    May 1, 2004
    624
    Beaverton,Oregon
    ok so now how do I GET TOO the wires and since my button has 2 posts...one goes to purple the other to red? /forums/images/graemlins/dunno.gif /forums/images/graemlins/dunno.gif
  6. big83chevy4x4
    Mar 22, 2002
    6,587
    Sheridan, Michigan
    yep one to purple, the other to red. just cut them off at the switch and run them up to the button.
    the switch is mounted ontop of the column.
  7. four_by_ken
    four_by_ken 1/2 ton status
    Jun 9, 2001
    3,806
    Allenton, MI
    On my old Jeep... just put the key in the on position, then push the button that was wired directly from the batterty and from the starter. Simple. Still needed the key to make it run, but not start.
    The ignition was gummed up with mud, so it was near impossible to turn the ignition to the start position without some channel locks or something. /forums/images/graemlins/cool.gif
  8. backyardbuilt
    backyardbuilt 1/2 ton status
    May 28, 2002
    1,301
    Olathe, Kansas
    I run mine the same way just a hot from the battery to the switch then to the selinoid on the starter still need the key on but no messing with the wires in the column. Works every time now did it the same way on my buddies toyota.
  9. supersize75k5
    supersize75k5 OrganDonorRacing.com
    Feb 3, 2004
    8,832
    4
    gilbert az
    I ran mine from the distibution block and to the starter, worked like a charm, dont wast time hacking a harness since you may want to undue this in the future..or the next owner /forums/images/graemlins/deal.gif
  10. smprider112
    May 1, 2004
    624
    Beaverton,Oregon
    thats what I was thinkin, is just run it directly to the starter instead...but wasnt sure if that would work (plus its easier...cuz im lazy /forums/images/graemlins/grin.gif)
  11. shane74
    shane74 1/2 ton status
    Feb 12, 2002
    4,100
    Vancouver, WA
    It'll work. I personally never hack into the existing wiring because you never know if you're going to have to undo anything.
    I'll tell you this though..you can pick up a brand new ign. switch with a key for about $10. You can install it in less than 1/2 hr if you have the right tools (I do /forums/images/graemlins/deal.gif). If you really want to go push button, cool. If you're just wanting a cheap and easy way to fix it, then a new switch & key is my vote. I guarantee I can swap out your ign. switch faster than you can install a push button and run the wires. /forums/images/graemlins/grin.gif
  12. smprider112
    May 1, 2004
    624
    Beaverton,Oregon
    YA SURE....NOW you tell me... /forums/images/graemlins/rotfl.gif /forums/images/graemlins/rotfl.gif /forums/images/graemlins/rotfl.gif I allready bought the pushbutton switch for like 8 bucks /forums/images/graemlins/rotfl.gif ohh well the "COOL" effect should be worth it /forums/images/graemlins/thumb.gif
  13. k5freak44
    k5freak44 1/2 ton status
    Jun 1, 2004
    2,164
    Plano, TX
    lemem get this straight...
    pink wire to red
    tap purple wire on red?
    car goes vrooom
  14. darkshadow
    darkshadow 1 ton status
    Dec 6, 2003
    12,250
    C-eh-N-eh-D-eh
    if you want to elemanate the key altogeather put a small push botum ant the base of the stering colume and paint it black so you don't see it. i have done it on a buddys car when the ign went for a crap.
    doing it on mine when i rip out the daash. /forums/images/graemlins/waytogo.gif
  15. Resurrection_Joe
    Resurrection_Joe 1 ton status
    Jan 9, 2002
    17,372
    Gettysburg, SD
    I have pushbutton on my K5, a momentary and two toggles, but the wipers dont work, so I guess I need another toggle.........
  16. js4x4
    js4x4 1/2 ton status
    Jul 17, 2004
    798
    San Diego, CA
    I'd return the cool switch and get yer $8 back...hes right, a wheel puller and your home free (its just compressing that friggin spring and gettin the c'clip in that gives me hell) but I swapped out my entire steering column, swapped the lock/tumbler from the 'old' to the new....in a couple hours. There is a tool to compress that spring, but pft...
