Push or Pull to Start?
Discussion in 'The Garage' started by hapynzap, Jun 13, 2003.
  1. hapynzap
    hapynzap Newbie
    Jun 13, 2003
    My son has a 83 K5 with 6.2 and auto trans (700r4?)
    Can you push or pull it to get it to start?
  2. gravdigr
    gravdigr 1/2 ton status
    Apr 15, 2003
    1,129
    Tyrone, PA
    nope sorry
  3. Blue85
    Blue85 Troll Premium Member
    Jul 26, 2000
    9,075
    486
    Grand Rapids area
    You can't push (or pull) start anything with an automatic transmission. Unless you somehow have a manual converter lockup you can do without the engine running...but I digress! Even if you had a manual transmission, the 6.2 is about 20:1 compression, so it would be hard to do. That's why the diesel has such a massive starter motor.
  4. BlazerGuy
    BlazerGuy 3/4 ton status
    Apr 20, 2000
    9,206
    abcde
    Like the others said, nope... [​IMG]
  5. CHEVY 4WD
    CHEVY 4WD 1/2 ton status
    May 14, 2002
    1,773
    Florida
    I dont know the diesal spec's but confedneck pull started a F250 on 42's thats had a 6.9 pretty easy but it also has a 4Speed.
  6. dyeager535
    26,979
    Not quite true /forums/images/graemlins/smile.gif
    The reason you can't pull or push start modern automatics is that the oil pump is driven off the engine crank, not the driveshaft. You can't engage the clutches without oil pressure, and you don't produce any pressure without the pump turning.
    Apparently (so my dad says) some old automatic transmissions had rear mounted pumps, so the driveshaft was what actually turned them, and those could be push or pull started.
  7. BlazerGuy
    Apr 20, 2000
    9,206
    abcde
    Yeah, the project K5 from 4Wheel&Offroad has a 700 that has a Accusump with an electric valve that can keep the clutches inside the tranny applied with the flick of a switch which I think would allow you to push start it... [​IMG]
  8. boggerless
    boggerless 1 ton status Premium Member
    May 26, 2003
    22,728
    96
    dearborn heights, Michigan
    you dad was right, my friend had a 63 belveder(i think thats how you spell it), with an auto and we push started it once in a while. you had to go pretty fast though,almost 35 to 40 mph. /forums/images/graemlins/k5.gifto /forums/images/graemlins/truck.gif
