push rods
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by 85blazer350, Nov 4, 2001.
  1. 85blazer350
    85blazer350 Registered Member
    Sep 5, 2001
    51
    Grande Prairie,Alberta,Canada
    Im swapping in a 350 and was wondering if the push rods off my 305 would work also would the rockers water pump,altternater ,what will I have to buy for the swapp.
    Thanks for all the help
  2. SCOOBYDANNN
    SCOOBYDANNN 1/2 ton status
    Sep 4, 2001
    2,129
    21
    El Paso, TEXAS
    I don't know if the rockers, or the pushrods, but everything outside the block will bolt on except the harmonic balancer and flywheel/flexplate
    Sun Desert Offroad <a target="_blank" href=http://4x4.alloffroad.com>4x4.alloffroad.com</a>
  3. 4x4blazer
    4x4blazer 1/2 ton status
    Jun 14, 2000
    278
    Louisiana
    The push rods and the rockers are the same for all standard small bock chevys (262-400). The only difference between a 305 and a 350 is the bore size. The 305 has a bore size of just 3.736 inches, and the 350 has a bore size of 4 inches. The stroke is the same, the rod-journal diameter is the same, as well as the main-journal diameter. So everything else should work.
    If I need corrected anyone, please do so, heh.
    Good luck with your swap!
  4. gator1959
    gator1959 Registered Member
    Nov 4, 2001
    36
    everything will bolt up internally and externally,don't use the harmonic balancer or the flywheel from the 305,the heads will also interchange.and the intake.and will also bolt right up to your exhaust system.and motor mounts.
    '79 K-5,D-44HD(8-bolt),14 bolt(FF),4.09 ratio,427 rat,auto,38" rubber,currently taking body off frame
