pushin blue
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by chevycanada, Jul 11, 2002.
  1. chevycanada
    chevycanada Registered Member
    Aug 14, 2001
    33
    Comox BC
    my motor has begun pushing blue alot lately, i did a compression test on it today and figure it would be low but every cylinder was between 180-190. i thought the rings were shot but i didn't think you would get that compression if the rings were gone. is there anything else it could be?
    any info appreciated
    thanks
  2. little79k5
    little79k5 1/2 ton status
    Mar 27, 2002
    230
    panama city, fl
    valve seals.
  3. Mingler
    Mingler Registered Member
    Nov 2, 2001
    29
    Calgary, Alberta
    Definitely your "Piston Return Springs".
    /forums/images/icons/wink.gif
    Or your valve seals!! /forums/images/icons/cool.gif
  4. Leadfoot
    Nov 28, 2000
    3,112
    Western Massachusetts
    If your noticing it at startup but not so much after driving it (maybe some at take-offs), I would say valve seals (which are a common problem). I don't know how mechanically inclined you are, but with a few tools and airsupply to hold the valves closed, you can do it while in the truck or you can have a mechanic do it (shouldn't be too much, but it all depends on where you are and who you go to). If you want more info let us know.
  5. chevycanada
    Aug 14, 2001
    33
    Comox BC
    if you could guide me on how to replace the valve seals it would be greatly appreciated. this is the second motor i have put in the truck its just a temporary thing until i get a new one built. i do have some mechanical knowledge so if you can let me know or point me in the direction of how to replace the valve seals it would be great
  6. MudbogAD
    MudbogAD 1/2 ton status
    Jun 29, 2001
    672
    Las Vegas Nevada, US
    It could be your valve seals and/or valve guides.
