Pushrod cleaning?
Discussion in 'The Garage' started by dremu, Feb 4, 2007.
  1. dremu
    Feb 27, 2000
    15,963
    454
    East of San Francisco
    I'm swapping cams while I have the motor out on my sixpack; motor's a 454, allegedly ~50K miles.
    I see the pushrods have marks or stains on them ... like from heat, more than actual mechanical wear. I haven't mic'd them, but there's no damage to be felt by the fingers, anyway.
    Sooo ... do I lightly sand them or hit them with an emory cloth or chemically treat them or anything to get rid of the striping, or is that normal and I'm worrying too much and I should just drop them in?
    Pic: http://www.slosh.com/ck5/big-block-teardown-5.JPG
    -- A
  2. cybrfire
    Dec 15, 2002
    15,140
    565
    Iowa
    if the marking you are seeing is more of a discoloration, drop them in and run 'em. EDit, Oh I see the pic, run 'em! Make sure they are clean inside and flowing free!
  3. 4X4HIGH
    Dec 14, 2001
    22,063
    70
    Pleasanton, CA.
    You can wash them with kerosene, laquer thinner, or even gasoline. Just make sure you install the pushrods in the correct positions. There are long and short pushrods. Also make sure they are STRAIGHT and CLEAN. Roll them on a piece of glass to check for straightness then look through them to make sure they are clean.
  4. dremu
    Feb 27, 2000
    15,963
    454
    Yeah, what that pic doesn't show is they are CAREFULLY laid out front to rear, left and right sets. The book made that painfully clear, and it looked like there was at least two different sizes of pushrods so I was careful not to mess with the order.
    Thanks all!
    -- A
  5. 4X4HIGH
    Dec 14, 2001
    22,063
    70
    Pleasanton, CA.
    No need to keep them in order. Just need to make sure they go back in the correct position of long or short and that they're clean and straight.
