Pushrod Length Checker Question
Discussion in 'The Garage' started by bigburban383, Feb 13, 2004.
  1. bigburban383
    bigburban383 1/2 ton status
    Dec 30, 2003
    1,242
    Michigan, Royal Oak
    How do you get the actual measurement, do you have to use a big caliper or something?
    /forums/images/graemlins/usaflag.gif /forums/images/graemlins/burb.gif /forums/images/graemlins/usaflag.gif
  2. Beast388
    Beast388 1/2 ton status
    Nov 6, 2001
    3,039
    Clinton, IA USA
    There is a tool out there that is basically a two piece pushrod the is threaded witha jam nut. To figure the correct length, you unscrew the tool until it is seated in the lifter and touching the checker tool. Then you tighten the jam nut and remove it. Measure it and that is the pushrod length you need.
    In my case, I used a set of feeler gauges to find the distance between my pushrod and the checker tool. I added that distance to the current puhrod length to determine the correct length that I required. /forums/images/graemlins/waytogo.gif
  3. bablazer73
    bablazer73 1/2 ton status
    Apr 4, 2000
    3,363
    upstate ny
    What he said!!
    Comp Cams makes a set Part # 7900
    I think the tool company "tavia" actually makes them. Jegs used to carry alot of their tools.
