Pushrod Mixup
Discussion in 'The Garage' started by 72THING, Apr 6, 2002.
  1. 72THING
    72THING 1/2 ton status
    Nov 26, 2001
    501
    Ranburne, AL
    When I replaced the heads on my 350, I mixed up the pushrods by accident. I've been told that this will damage the rockers and lifters. Should I replace my pushrods? My engine seems to run fine and I've adjusted my valve lash with the engine running by loosening until I hear them clatter, then tightening half a turn. It seemed to work just fine. I just don't want to damage my engine. Thanks,
    Will
  2. 4X4HIGH
    Dec 14, 2001
    22,063
    71
    Pleasanton, CA.
    You will be fine, it doesn't really matter if you mix them up or not. They do develope a wear pattern in the rocker arm and lifter plunger but it is so minimal that it doesn't matter.
