Put a new distributor in- WOW!
Discussion in 'The Garage' started by odoa3, Oct 5, 2004.
  1. odoa3
    odoa3 1/2 ton status
    Mar 31, 2004
    1,638
    Anchorage, AK
    I rebuilt my 350 and have had a hard time getting it to run as well as I want. So, I finally picked up a Mallory HEI distributor and put it in the weekend. What a difference! I had basically rebuilt my old one and figured it was fine. Don't know what was wrong with it- but I actually have power now. /forums/images/graemlins/woot.gif Having been a Ford guy my whole life, I was starting to think Chevy's really were slugs. LOL Now if I can just figure out how get full throttle I will be styling!
  2. down4thakrown
    down4thakrown 1/2 ton status Premium Member GMOTM Winner
    Aug 5, 2003
    1,760
    75
    flagstaff,az
    /forums/images/graemlins/thinking.gif
  3. Topdown
    Topdown 1/2 ton status
    Nov 26, 2002
    2,598
    Vancouver, Washington, U.S.A
    do what I did... bend your throttle bracket backwards so that it pulls farther /forums/images/graemlins/thumb.gif /forums/images/graemlins/screwy.gif
    Or, you could do what I did after that broke, go buy the correct bracket /forums/images/graemlins/whistling.gif
  4. jekquistk5
    jekquistk5 Weld nekid Premium Member GMOTM Winner
    Jan 18, 2004
    11,005
    836
    Pinckney, MI
    hmmmm./forums/images/graemlins/thinking.gif /forums/images/graemlins/thinking.gif chuck up distributor on things to buy for truck!!!
  5. odoa3
    Mar 31, 2004
    1,638
    Anchorage, AK
    I have the correct bracket now, so I think I am going to be looking for the wrong one to use. /forums/images/graemlins/histerical.gif
    jekquistk5- I would highly recomend it. I ordered out of Summitt - $150 for everything you need. Heck, I think I am going to order the MSD plug wires now. If I got that much out of the dist. - changing the wires from stock to MSD should help out as well. /forums/images/graemlins/thinking.gif
  6. tch777
    tch777 1/2 ton status
    Jan 15, 2003
    244
    Colorado Springs, CO
    what are the specs on your truck and engine there is nothing in your signature?
    What year and such would be nice.
  7. odoa3
    Mar 31, 2004
    1,638
    Anchorage, AK
    Tch777,
    It is a '75 K5. Bought it in April with a pretty well trashed 350. It had just been recently rebuilt it looked like- by someone who knew even less then I did. All the cylinders were different sizes- bored .062 and up. One rocker was not even on the push rod, I found freeze plugs that had just been pushed into to the block- and the list goes on.
    Got a different block- bored forty over, replaced everything between the intake and oilpan. Put in an RV cam-don't have the numbers here. Also put new heads on. Has a Wiend (sp?) intake and a Edelbrock Performer 1406 on it. Next weekend the offroad needles go in that. Topped it off with a K&N.
    Flowtech headers are in back waiting to go. This winter a six inch BDS lift is going on with 36 Swamper TSL's or 35 inch Boggers. At the same time a 14 bolt with a spool is going in, and a eight lug Dana 44, both out of a 3/4 truck are going under it. Putting on ORD greaseable bushings and front shackle, as well as a steering brace. Have to start getting all the parts on, my buddy is getting sick of stuff laying around his house. /forums/images/graemlins/whistling.gif I have to get a garage!!!
    Other spec's- TH350 and 203. Need to find a 205. I have been waiting for three years, saving money and wishing for an off-road truck. Hopefully, I won't be disappointed when it is finally to the point where I can go have some fun. Couple pic's in members rides from the day I got it- search with username odoa3.
  8. rhuarc31
    rhuarc31 Registered Member
    Oct 21, 2003
    94
    Decatur, IL
    Heck, just bend your the bar on your throttle pedal to get more travel. That's what I did to get full throttle, worked great.
