Put All New Heat shielding on Electrical System Today
Discussion in 'The Garage' started by 1-ton, Aug 23, 2004.
  1. 1-ton
    Apr 17, 2004
    2,890
    167
    Las Vegas, Nevada
    Home Depot has "Split Flex Tubing" for about $0.50 cents a Ft. I bought 30 Ft. of the stuff for $15. They have it in 3/8", 1/2", and 1", and is rated for -40 to 300 degrees Fahrenheit. When I bought the truck most of the electrical heat shielding had dry rotted away, and most of the wiring was lying bare on or in a hot engine compartment.
    My truck was having a problem where the "check engine" light would come on, and it would start running like it was in 'open loop'. I noticed that the only time the light would come on was when I hit a bump, or turned a corner a little quickly. I figured the problem was an exposed electrical wire getting grounded when it was banged around because all the electrical heat shielding was rotted away. Apparently I was correct, after driving the truck around for several hours, hitting bumps and turning corners quickly, the "check engine" light never came on, which it would normally have after that amount of driving time.
  2. sickquad
    sickquad 1/2 ton status
    Jul 23, 2003
    785
    Ma
    Is this Home Depot flex tubing just the regular plastic stuff that comes in a bag or something special? Did you find it in the electrical section ment for housing applications?
    -Chris
