put on the 4 in tuff country, now what else...
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by Sparky, Aug 16, 2001.
  1. Sparky
    Sparky 1/2 ton status
    Aug 20, 2000
    423
    San Antonio(summer) Texas A and M (school year)
    Well I put on my new tuff country EZ ride lift and drove it around a bit. Drives real nice except for two problems. 1-I dont have any shocks front or rear which will be fixed tomorrow. 2-I get some bump steer now. With my 2 inch lift I did not have any bump steer but it had to go because it was way too stif. Does the lack of shocks contribute to the bumpsteer? I just want to know now so I can decide what else I need to get to correct the problem like some swaybar correction/disconnects. What else can I do to make the bump steer go away? Thanks in advance. Hopefully I can get some pictures up soon. I'll be sure to get some twisting it up pretty good.
    Sparky
    When all else fails... Check the blinker fluid.
    78 K-5
  2. solowookie
    solowookie 1/2 ton status
    Mar 31, 2001
    3,880
    Wyoming
    I'm sure there are more qualified people here, but I'd look at your steering stablizer... a new one is not too much!
    <font color=blue> Jeff - may the force be with you</font color=blue>
    <a target="_blank" href=http://coloradok5.com/gallery/Jeffs-Stuff>http://coloradok5.com/gallery/Jeffs-Stuff</a>
  3. gokartergo
    Dec 2, 2000
    5,855
    Hollister, CA
    Put on a raised steering arm made for lifts. It helps a lot and the swaybar disconnects help too.......Dan
    If it ain't broke.......Don't fix it....
  4. MudbogAD
    MudbogAD 1/2 ton status
    Jun 29, 2001
    672
    Las Vegas Nevada, US
    Get a raised steering arm. My Friend just got a lift and he got one for about 35 bucks.
    Adam
  5. 502Burban
    502Burban 1/2 ton status
    Jun 8, 2001
    379
    Southern California
    Try temporarily disconnecting your swaybar. A good friend with a K5 and 4" lift had bumpsteer problems. Tried replacing ball joints, steering box, intermediate shaft. No improvement. And he already had the lifted steering arm. Installed poly bushings on the sway bar. This made things worse, but gave us our clue.[​IMG] Installed ORD's swaybar disconnect/correction kit and the bumpsteer went away for good. Another great product from ORD!
    If you disconnect your swaybar and the problem disappears, then install ORD's kit. You won't regret it.
    Robb
    '73 GMC Suburban - 502DFI
    <a target="_blank" href=http://community.webshots.com/user/robbrj>community.webshots.com/user/robbrj</a>
  6. Sparky
    Aug 20, 2000
    423
    Well, my steering stabalizer is already a single rancho rs5000 so I dont think that is the problem. As for the sway bar disconnects, I just might purchase some. I'll see how scary it is once I have my shocks on. Then i'll disconect the sway bar and if that fixes the problem I'll get the disconnects.
    Sparky
    78 K-5
  7. solowookie
    Mar 31, 2001
    3,880
    Wyoming
    you also might want to get some larger bump stops to help your springs live longer...
