Put these modifications in order....
Discussion in 'The Garage' started by 78Suburban, Aug 9, 2006.
  1. 78Suburban
    78Suburban 1/2 ton status
    Jul 4, 2005
    2,609
    Georgia
    ok guys, the next thing on my list is to get the burb lincon locked in the rear. After that I want to do the disk brake conversion.. After that, there's several options:
    Beadlocks (either DIY, or try to find recentered h1's)
    crossover steering
    WFO concepts DOM tie rod
    high lift jack
    electric air compressor
    heavy duty diff cover for 14ff
    very simple cage made from HREW
    What order should the above go in?
  2. readymix
    readymix 3/4 ton status
    May 30, 2004
    6,706
    26
    Murrieta, California
    7.....Beadlocks (either DIY, or try to find recentered h1's)
    2.....crossover steering
    3.....WFO concepts DOM tie rod
    1.....high lift jack
    4.....electric air compressor
    6.....heavy duty diff cover for 14ff
    5.....very simple cage made from HREW
  3. muddybuddy
    muddybuddy 3/4 ton status
    Jan 29, 2004
    8,933
    Fairfax Station VA
    i can agree with that...#5,6 and 7 could be in any order tho
  4. hack500
    hack500 1/2 ton status
    Sep 16, 2005
    523
    Templeton, Ma
    #1 hi-lift.
    as for the other stuff, any order.
  5. pvfjr
    pvfjr 1/2 ton status
    Feb 10, 2004
    2,425
    Oakridge, OR
    Hi Lift #1
    I'd save the crossover project for your Dana 60.
    I wouldn't use an electric compressor, definitely go York.
    Big tie rods are always good, and should mostly swap over to your Dana 60.
    The rest you can just do when you feel like it, or can afford it.
  6. NoReGrEtS
    NoReGrEtS 1/2 ton status
    Nov 7, 2005
    848
    Moreno Valley,SO CAL
    1.....Beadlocks (either DIY, or try to find recentered h1's)
    7.....WFO concepts DOM tie rod
    5.....high lift jack
    3.....electric air compressor
    4.....heavy duty diff cover for 14ff
    6.....very simple cage made from HREW
    I went ABC order:D
  7. Hossbaby50
    Hossbaby50 3/4 ton status
    Sep 1, 2001
    8,972
    Peoria, AZ
    1. Cage
    2. Hi-lift
    3. HD Cover
    4. HD tierod
    5. Crossover
    6. Beadlocks
    7. Compressor
    I personally think Cage should be #1. Safety should be #1 priority. Everything else comes afterword. I wouldn't do crossover or hd tierod until the D60 is ready if it will be ready soon. The HD tierod would have to be shortened and the draglink would be shorter also I believe. The knuckles and steering arm would be useless except to resell for used prices.
    Harley
  8. blazinzuk
    blazinzuk Buzzbox voodoo Premium Member GMOTM Winner
    Dec 20, 2002
    17,412
    3,799
    Afton / Star Valley Wyoming
    I agree with some of the suggestions if you are going to go D 60 keep your crossover conversion on the half/ three quarter ton stuff as cheap as you can.
  9. southernspeed
    Dec 24, 2003
    4,395
    50
    VA
    Jack, get you out of many situations and stucks.
    Crosover.
    Beadlocks, aired down tyres will get you out of a lot of trouble too.
    Compressor to air up!
    Cage, as now you can get out of trouble you may push your luck a bit more.
    Tie rod as you're getting intpo trickier situations.
    Diff cover for same reason!
