puter people, click here if you will.......
Discussion in 'The Lounge' started by gotmud?, Dec 18, 2002.
  1. gotmud?
    gotmud? 1/2 ton status
    Feb 23, 2002
    1,172
    up north
    My sister just gave my dad her old puter, but he say's it stick's on the "start-up" screen, then has to boot in "safe mode" and it does'nt see the monitor or the cd rom drive /forums/images/graemlins/confused.gif I'm going up there Sun. Where do I start?? Should I just try to RE-format the drive? Can I boot from a win 98 CD? Thank's for any help....
  2. Muddytazz
    Muddytazz 1 ton status
    Jun 30, 2002
    20,073
    Salem, Or.
    Sounds like something is screwed up in the boot sector of the harddrive, me personally, I'd just format the drive and start over fresh.
  3. shewheeler
    shewheeler 1/2 ton status
    May 4, 2001
    3,384
    Hollister, CA
    You can also try running scandisk after it starts in safe mode. Do the surface scan as well... or... just reformat/forums/images/graemlins/grin.gif
  4. Sandman
    Sandman 3/4 ton status Author
    Apr 15, 2002
    5,653
    Pocatello, ID
    Yeah, just start over. And yes you can boot from a 98 CD. It should give you the options to format the drive before an install also. "Should" be a pretty painless deal. Good luck with it. /forums/images/graemlins/grin.gif
  5. TopOff
    TopOff 1/2 ton status
    Jan 16, 2002
    1,760
    Folsom, ca
    When it only goes into safe mode, it is either a network problem or a video problem. If you have no network, than you have a video problem.
    Good luck.
  6. gotmud?
    Feb 23, 2002
    1,172
    up north
    Thank's for the info. Look's like I'll just re-format. probably will be much easier than trying to trouble-shoot.
  7. rogerwilco71
    rogerwilco71 1/2 ton status
    Sep 22, 2002
    179
    Central-Cal
    I'm always for a good format and reload /forums/images/graemlins/thumb.gif Before going into safe mode, try pressing F8 at the second post screen and select command prompt (I thinks its #5), then type "scanreg/restore" (w/o qoutes) then enter.
    There you can find a previous start up that actually booted. Other than video, it can sometimes be an issue/power irregularity with the motherboard. If you hang on reloading windows (w/ clean format) it's definetly hardware related.
  8. chevyracing
    chevyracing 1/2 ton status
    Sep 8, 2001
    2,589
    Colorado
    Wut you talkin' bout Willis???????
