PUttin in MSD any thoughts or tips?
Discussion in 'The Garage' started by broncoman6524, Mar 28, 2006.
  1. broncoman6524
    broncoman6524 1/2 ton status
    Oct 31, 2005
    2,469
    chuluota Fl
    I bought Msd 6a this weekend and im gonna put it on tomarow maybe. Any tips as to where is the "best" place to mount it or what not to do? I was thinkin on the fender next to the battery, or on the fire wall between the Dist and A/c
    BTW im not gonna need a bigger alternator or anything rights:confused:
  2. JeffHK5
    JeffHK5 1/2 ton status
    Mar 16, 2005
    544
    Cincinnati
    Stock alt is just fine!
    Put it in a protected place away from extreme heat and excessive water contact , and resist the urge to not use the little rubber isolator feet.
    I have mine in a ammo can with a couple ATV airbox vents, they let air in but keep 99% of the water out.
    The number one way to help keep a MSD box alive is to never weld on the rig with the +/- cables hooked up! This info is out of the mouth of a MSD service tech.
    I have no idea what the guys with Mobi/Ready onboard welders do.:confused:
    Good luck, Jeff
  3. Greg72
    Mar 5, 2001
    15,683
    1,392
    642 Days to BB2018
    I put my 6AL box up behind the guage cluster on the interior of the firewall.
    I figured it was a lot less likely to get wet if I put it in the cab with me. There was plenty of room behind the gauges too....
  4. 87350blaz
    87350blaz Registered Member
    Oct 23, 2005
    33
    New Mexico
    i helped a buddy install one and afterwards his stereo had a loud electical popping noise in it. But i think you can get a filter from radio shack to fix it.
  5. Chevy305
    Chevy305 6 Lug 14bsf Status Premium Member GMOTM Winner
    Jan 23, 2006
    11,232
    490
    New Hampshire
    How much more power can you expect from a 6A?
  6. nad
    nad 1/2 ton status
    Dec 29, 2005
    1,537
    Festus, MO
    A guy I know has his mounted in his glove box so he could lock the glovebox. I think he used his as more of a battery shut off to prevent theft though...
  7. 87350blaz
    Oct 23, 2005
    33
    New Mexico
    well what kind of power are you talking about?
  8. sweetk30
    Nov 1, 2004
    25,548
    543
    horseheads , ny 14845
    i killed my 6al and then warrentyed it for a swap out to a off road box. better unit full of shock absorbent stuff. and wether pack terminals. also major thing use the rubber isolators to mount it. or this will give you quick death to the box.
  9. dontoe
    May 7, 2004
    9,070
    Hickory, N.C.
    I noticed a big improvement in idle, takeoff and long uphill pulls. :laugh:
  10. JeffHK5
    Mar 16, 2005
    544
    Cincinnati
    I was always a fan of the 6AL box , built in rev control is nice for people with power judgment or lack of sense;) . I set my selector module to 5K and let it fly.
    Jeff
  11. sweetk30
    Nov 1, 2004
    25,548
    543
    my old 350 oil burning monster would run better also and got 5k miles more out of plugs . :eek1:
  12. broncoman6524
    Oct 31, 2005
    2,469
    chuluota Fl
    Mine didnt come with any rubber feet. What do you suggest? i was gonna use about and inch of vacuum hose and just squeeze it down.
  13. Cornfield creations
    Cornfield creations 1/2 ton status
    Oct 19, 2005
    1,283
    Jasper, Indiana
    I have a 6AL on my 63 impala ss, saved my engine when the throttle stuck wide open when i got on it. Had it set at 6k, runs awesome.
  14. RootBreaker
    Nov 29, 2001
    5,118
    173
    Williamstown, NJ USA
    WOW I bounce over 5k all the time.!!!!! my lack of sense.. and a heavy right foot plus alot of muddy water!!!!! :haha:
  15. k20
    k20 3/4 ton status
    Sep 9, 2001
    5,068
    Mineral Springs, NC
