Puttin new Pipes on the truck... Should i have them Put an "H" pipe in ther
Discussion in 'The Garage' started by Silver84k5, Jun 4, 2004.
  1. Silver84k5
    Silver84k5 1/2 ton status
    Feb 7, 2002
    3,769
    Hillsboro Oregon
    Puttin new Pipes on the truck... Should i have them Put an \"H\" pipe in ther
    title pretty much says it all... Thx.
  2. pauly383
    Jul 22, 2001
    16,217
    Mesa , Arizona USA
    Re: Puttin new Pipes on the truck... Should i have them Put an \"H\" pipe in
    It balances the exhaust system. Too tired to get into details, but the exhaust pulses even out. It will queit it a bit too, but its all around better from a technical standpoint /forums/images/graemlins/k5.gif
  3. POWERMAD
    POWERMAD 1/2 ton status
    Mar 4, 2001
    3,466
    Oregon
    Re: Puttin new Pipes on the truck... Should i have them Put an \"H\" pipe in ther
    You've seen(heard) my stuff.
    As soon as the engine is done I plan on that.
  4. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    I don't know about quieting the exhaust, they say it does but in my experience, I haven't noticed that.
    It does sound much better though!
  5. FWP
    FWP CRS
    Oct 11, 2000
    3,845
    3
    Prescott Valley, AZ
    Yes and no IMHO, depends. I would do one on mine, but the rocks would eat it alive, and I want to be able to access the driveline on the trail without a pipe in my way.
  6. ugly_blazer
    ugly_blazer 1/2 ton status
    Apr 12, 2004
    1,214
    Quite a while ago I read an article in a magazine where they were testing different exhaust systems. All of the tests were done on a dyno using the same vehicle. They tested open headers, duals with an h-pipe, and duals without an h-pipe. The system that put out the most hp and torque was the full exhaust withOUT the h-pipe. I think that it depends a lot on the engine, pipe size, vehicle, etc...
  7. big pappa b
    big pappa b 3/4 ton status
    Jan 3, 2003
    6,328
    Falcon, Colorado
    I would say it depends on how you are going to use the truck. If it's something that will see limited street time and mostly trails with low rpms..don't do it.
    Street driven mostly then I would consider it
  8. Poohbair
    Poohbair 1/2 ton status
    Jan 30, 2003
    2,139
    Ellensburg, WA
    It is my understanding that a X pipe is more effective than an H pipe.
  9. 4xcrazy
    4xcrazy 3/4 ton status
    Oct 31, 2003
    9,471
    5
    Olympia/Lacey, Washington
    Yeah, it makes it sound like a single exhaust system with dual out tips, you don't get the destinguished left and right bank sounds, you get all of them, so why not just save some weight and money and install a 2.5 or 3" single with dual out the muffler.
    Makes more sense to me, less material to get damaged and out of the way.
  10. Silver84k5
    Feb 7, 2002
    3,769
    Hillsboro Oregon
    i just bought the mufflers im thinking of just doing true dual without that h pipe..I got 2-1/4" 50 series 3 chamber flows
  11. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    Well I have straight duals on my trail rig and duals with a crossover on my tow rig.
    The tow rig sounds soooooooo much better hands down. I'm almost inclined to say that I can't stand the way my trail rig sounds after driving my tow rig this week. /forums/images/graemlins/thumb.gif
  12. Thunder
    Thunder 3/4 ton status
    Jul 20, 2000
    8,946
    Northeast Nevada
    H pipes dont help Chevys a whole lot. They do make them sound better though.
    H and X pipes do a lot more for 5.0 HO and 351 Winsor powered fords because of their fireing order. 1-3-7-2-6-5-4-8. With 3 plugs on one side firng after each other a X or H pipe balances exahust and reduces backpressure.
    Chevys firing order is more balanced 1-8-4-3-6-5-7-2 so you dont see gains with a H or X pipe like you do with Fords. So they really aren't needed for performance.
  13. mtn. burb
    mtn. burb 1/2 ton status
    May 13, 2004
    1,260
    Ojai Calif.
    Good answer. How significant are the gains with complete dual exhaust vs. headers into single 3" exhaust? I would like to eliminate the pass. crossover pipe from pass. side to driver side collector.
  14. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    There is absoultely no benefit to duals instead of a 3" single. Both are equally efficient. In fact, a 3" single is likely to be more efficient.
    I run duals just because they're easy to install and I didn't have to pay someone to bend them.
  15. Cmoe
    Cmoe 1/2 ton status
    Feb 19, 2000
    2,884
    Mesa,AZ
    [/ QUOTE ] This is what I
    m running on mine right now. Mine is a '78 that came stock with this from the factory (without CAT's) so I went with dual 2-1/4" that are dumped right behind the rear tires, Flowmaster 50 series. I'm very happy with this set up..... Some times I wish I would have gone with a quieter muffler, but oh well......
