Puttin on a Spindel
Discussion in 'The Garage' started by CHEVY 4WD, Apr 6, 2003.
  1. CHEVY 4WD
    CHEVY 4WD 1/2 ton status
    May 14, 2002
    1,773
    Florida
    Ok I took off the spindle an backing plate(10bolt) but now im trying to put it back on I moved the axle ujoint and axle stub around and I cant get the spindle to go back on I can just barrley get it to go over the treads but then it wont slide all the way back(I even used a hammer lighly) if i try to put it on with out the backing plate it goes on but still not all the way Anyone know what im doing wrong? /forums/images/graemlins/1zhelp.gif /forums/images/graemlins/confused.gif
  2. K5MONSTERCHEV
    K5MONSTERCHEV 1/2 ton status
    Jan 27, 2003
    3,254
    Castro Valley, CA
    Your putting the spindle on first, correct?
  3. Corey 78K5
    Corey 78K5 1 ton status
    13,055
    Humboldt County, CA
    They tend to be a tight fit. Make sure nothing is distorted or mared. Then get it all lined up and place a block of wood up aginst it and then use a hammer. The block of wood will protect the spindel. Just don't get carried away.
  4. CHEVY 4WD
    May 14, 2002
    1,773
    Florida
    But how are you gonna hit the spindle with the wood there?
    You will hit the axle stub /forums/images/graemlins/confused.gif
