Puttin on the lift.. few ?
Discussion in 'The Garage' started by stockk5, Dec 13, 2004.
  1. stockk5
    Apr 13, 2004
    2,035
    71
    Cromwell, CT
    i started to put on my lift last night, its a 4" rough country, springs in front obv. blocks rear. I got everything off the front end really easily except for the front bolts on the leaf springs. On both sides. They are stuck in there sooooooooo solid no matter how much hammering we do they do not slide out, we tried to used ratchets because maybe they were threaded.. but no cuz they only make the coil on the end of the leaf spring get tighter. Its like this on both sides, any clue at all how to get them out?
  2. B_to_C
    B_to_C 1/2 ton status Author
    Jan 15, 2003
    1,861
    In Government Housing
    This happened to me on my rear spring eye bolts. After i full day of hammsering and trying with a angle grinder, I just had a guy come over with a portable torch and torched those mothers off. :weld: :waytogo:
  3. cbbr
    Jul 17, 2004
    14,681
    High velocity, Low altitude
    WD40 overnight. Lots of it. Also, I found that a 5lb sledge helped with some bolts. Just a light tap or :doah:
  4. jkce457
    jkce457 1/2 ton status
    Nov 22, 2002
    135
    Southbury, CT
    I got mine out with a sawz-all :hack: and an air chizzle.
  5. Emmettology 101
    May 9, 2000
    8,126
    FL
    Torch is your best bet! :thumb:
  6. stockk5
    Apr 13, 2004
    2,035
    71
    Cromwell, CT
    where do you cut it apart? if the bolt is covered by the spring and all that crap? i only have a 4" angle grinder as well, i might be able to get a torch but it would be hard. thanks for all the info.
  7. cbbr
    Jul 17, 2004
    14,681
    Get a cutting blade (Lowes or Home Depot) and cut the head off. May be easier to "tap" out then. Also WD40 overnight from both sides.:grind:
  8. jekquistk5
    jekquistk5 Weld nekid Premium Member GMOTM Winner
    Jan 18, 2004
    11,014
    848
    Pinckney, MI
    Dont be affriad to cut the rubber bushing. I got mine off with a 7" grinder. Thats your best bet
  9. chrisb420
    chrisb420 1/2 ton status
    Aug 6, 2004
    652
    Binghamton, NY
    i just had to cut mine off with cutoff wheel the other day it wasnt a huge problem it took me longer to dig around the garage for a pair of bolts that would fit.
  10. slyguy_22
    slyguy_22 1/2 ton status GMOTM Winner
    Dec 13, 2004
    789
    Lancaster, PA
    Do yourself a favor and just cut the shackles off and get new ones, you can get them and bolts for $20-40. Im sure ur originals were like mine rusty and they were realitvly thin compared to the new ones.
