putting 1410 yoke on 1350 shaft?
Discussion in 'The Garage' started by muddybuddy, Oct 3, 2006.
  1. muddybuddy
    muddybuddy 3/4 ton status
    Jan 29, 2004
    8,933
    Fairfax Station VA
    ive got a 1350cv ford driveshaft that im going to run in the rear and i want to upgrade to a 1410 u-joint at the 14b. can i just take th shaft to a shop and have them cut off the 1350yoke and have them weld on the 1410 yoke or is it more complex than that? id take it to a shop because i want to make sure its balanced since the truck is street driven.
  2. muddybuddy
    Jan 29, 2004
    8,933
    Fairfax Station VA
    im sure someone has tried to put a 1410 yoke on a shaft they already had instead of buying a completely new shaft??
  3. sandawgk5
    sandawgk5 3/4 ton status
    Oct 28, 2003
    6,881
    Kitsap County PACNORWEST
    Not sure if the spline end is a standard size and spline count but I know HAD sells a 1410 upgrade for their shaft that only replaces the female end of the shaft. Can't you cut the 1350 off and just weld on a 1410?
    Ira
  4. nvrenuf
    Jan 7, 2002
    13,088
    252
    Mobile, Al.
    It should be do-able assuming it's a common size tube. It's going to be dictated by the size of the tube and the availability of a yoke for it.
    I realize this answer is obvious but you'll really have to call the shaft builder to find out.
  5. muddybuddy
    Jan 29, 2004
    8,933
    Fairfax Station VA
    hmm, well its a factory f350 stupid duty front driveshaft. ill have to measure and find out.
