putting a 3/4 ton 14bff under my 3/4 ton suburban... e-brake question
Discussion in 'The Garage' started by muddysub, Jan 5, 2003.
  1. muddysub
    Jun 23, 2001
    10,452
    489
    my garage, Henderson, NV
    ok i got this awesome 14bff with 4.10 and a detroit in it and it's going under the sub this month. it's 3/4 ton so the spring perches are the same, the u joint is the same, the brakeline is the same, BUT, the e-brake cables are different. this axle has 2 cables coming from it of equal length and my sububan has one short and one long cable that both run to the drivers side of the axle where they go to the front of the truck. how can i make this work? could i remove the cables from my 14bsf and put them on this 14bff?
  2. muddysub
    Jun 23, 2001
    10,452
    489
    anyone?
  3. woody9
    woody9 1/2 ton status
    May 27, 2001
    602
    Howell, MI
    not sure this is what you're going to want to hear.. but if i recall from the posts on here, i think you've got 4 options... (my 80 axle had same design as you described; my sub has the same cables you have).
    1. change in backing plates to match what you've got on the truck. believe it's a 'year' thing, but not sure the cutoff years and if theres any other backing plate swap issues.
    2. go disk! /forums/images/graemlins/smile.gif use the caddy calipers.
    3. there's been some posts about custom cables. not sure price, but sure it can't be too awful. Check the master link list and see if they might be listed there.
    3. Parking brake is optional equipment. Tie off existing cables and be done! (the option i took for now).
    Hope it helps..
  4. heavy4x4
    heavy4x4 1/2 ton status
    Aug 28, 2002
    3,270
    Delafield, Wisconsin
    woody9, you might want to check on that "optional" thing.
    Apparently in Wisconsin...it's not optional...it's the law. That's what I understand, anyway, being that the one time I've been pulled over in my 'burb, the state trooper had me test my parking brake right on the side of the interstate....he was an A-hole though. Just helping you stay legal /forums/images/graemlins/wink.gif
  5. muddysub
    Jun 23, 2001
    10,452
    489
    options 4 and 2 sound good. it'll be disc within 4 months anyway.
  6. muddysub
    Jun 23, 2001
    10,452
    489
    not in NV, no ispections except for smog. /forums/images/graemlins/grin.gif /forums/images/graemlins/grin.gif
  7. heavy4x4
    Aug 28, 2002
    3,270
    Sweet, well then...if I were you, #4 is what I'd do until you get the stuff for a disc conversion.
    Jim, unless you're not worried about it...you may want to do something about your p-brake setup so that you don't get a faulty-equipment violation. (Reminder: I'm just assuming it's law in Wisconsin since the cop had me test my p-brake to make sure it still works, I don't know that it's law for a fact.)
  8. rockink5
    rockink5 1/2 ton status
    Feb 6, 2002
    693
    Tracy, CA
    I thought you could take the s/f backing plates and use the on the f/f, but then again I am probably wrong /forums/images/graemlins/ignore.gif. You CAN modify your existing cables(short and long) to work in the f/f backing plates, without spending a dime. /forums/images/graemlins/thumb.gif
  9. thatK30guy
    Jan 12, 2001
    32,076
    55
    You CAN take SF and FF backing plates and swap them for the other, very easily, as long as......
    1. They both use the same size shoes.
    2. They both are 3/4 ton plates.
    The cut-off year is '82 and '83. '82 and older have equal length cables while '83 and newer have the passenger side longer than the driver side.
    Any 3/4 ton SF backing plate will fit ALL of the FF axles, regardless of the year. The trick is to find the correct years of plates to fit them to whatever year the truck is. After the correct plates have been found and fitted, it shall pass all inspections. /forums/images/graemlins/thumb.gif
  10. MudbogAD
    MudbogAD 1/2 ton status
    Jun 29, 2001
    672
    Las Vegas Nevada, US
    well, I guess you need the disc conversion sooner than expected. Unless you don't care about the e-brake.
  11. woody9
    May 27, 2001
    602
    Howell, MI
    Yikes! /forums/images/graemlins/eek.gif you're right! Just checked W-DOT code, and sho'nuff! Supposed to have 'em! /forums/images/graemlins/deal.gif
    Well, i've only been stopped twice in Wis - Both times by Ft McCoy /forums/images/graemlins/angryfire.gif Rent-A-Cops.... Guess I'll have to start huntin down some caddy calipers!
  12. BlueOx
    BlueOx 1/2 ton status
    Aug 6, 2000
    239
    Houston, Tx
    Muddysub, there is another way to do it by just modifying the cable holder on the new backing plate ( ie. for the new axle). It is a real eazy thing to do and it will save you money to use elsewhere. I will post some pics for you to see later when I get home.
    Charles
  13. muddysub
    Jun 23, 2001
    10,452
    489
    well i never use my e-brake anyway so i'll just zip-tie them to the axle and start buying disc conversion stuff.
  14. yeild2me
    yeild2me 1/2 ton status
    Jan 7, 2001
    1,309
    fayetteville, nc
    I have the backing plates you need. they are complete with nice shoes on them. Its just a matter of un-bolting yours, and bolting on these. PM me if you are interested.
    Rob
  15. pomai
    pomai 1/2 ton status Premium Member
    Jan 26, 2002
    435
    3
    Oahu, Hawaii
    I will be installing a 14 bolt ff soon in to my 88 blazer, but it had the equal lenght parking brake cables. I took the backing plates W/shoes off of a 1984 chevy 1 ton van with a 14 bolt sf. it had the same cables stlye as the one in my 88 blazer where the 2 cables were routed on the drivers side together. Ed
  16. BlueOx
    Aug 6, 2000
    239
    Houston, Tx
    This is the way I modified the e-brake cables on the old style to fit my new style brake cables. First take off the e-brake cable holders in the older 14 bolt (2 bolts do it). Then pry the two parts of the holder off the e-brake. Next cut the cable off so you can get the cable off the smaller piece (you'll see when you get that far). Then cut a slot in the smaller piece to slide in the new cable from your axle PIC . As you can see the larger piece of the cable fits into the larger piece of the holder PIC . Then just run the cable it's self through the smaller piece and sandwich the two pieces together PIC. Bolt the holder back into the backing plate and have fun. Best of all its FREE. If you need more info feel free to ask.
    Charles
  17. scrappyk5
    scrappyk5 1/2 ton status
    Mar 17, 2002
    2,099
    virginia
    heres a suggestion , this is how i am going to do mine.
    on the earlier volkswagons , the beetles , they have the same type of e-brake cables . one coming form each side.
    now what i was going to do , is use a vw e-brake handle,
    mount it to the floor next to the seat. drill the proper
    holes for the cables to come through , connect it up , adjust and all should be good. i am not positive this will work for you , but its the route i have drawn up and gonna go with . plus the cost is way cheap.
  18. yeild2me
    Jan 7, 2001
    1,309
    fayetteville, nc
    I had originally considered this in my blazer when I put my old school 14ff in last spring. The only differnce was tht I was going to hace two levers and have each lever control one brake.....like cutting brakes.
    never did it though...got busy with other stuff.
    rob
  19. HarryH3
    HarryH3 1 ton status Author
    May 31, 2000
    10,384
    Georgetown, TX
    Your links don't work. /forums/images/graemlins/frown.gif You were logged in to Webshots in edit mode when you copied 'em. Since we can't edit your web page, it won't let us in. /forums/images/graemlins/shocked.gif
  20. BlueOx
    Aug 6, 2000
    239
    Houston, Tx
    Sorry about that. It was late when I did that. It should work now. /forums/images/graemlins/grin.gif
    Charles
