Putting a 6.5 fan clutch on a 454?
Discussion in 'The Garage' started by afroman006, May 13, 2006.
  1. afroman006
    afroman006 1/2 ton status
    Aug 21, 2002
    2,876
    On my DD crewcab, a 98 K3500 with a vortec 454, the motor has been getting hot at lights and either my thermostat is sticking or my fan clutch is going out. Naturaly, I am going to replace the thermostat first but if that doesnt fix it I am looking into upgrading the clutch when I replace it. Is the clutch from a same year 6.5L TD a bolt on no-modification replacement? I figured it would either pull the same or more air than the stock 454 clutch.
  2. opfor2
    opfor2 1/2 ton status
    Oct 28, 2002
    375
    Ventura County, CA
    Sounds like the fan clutch is not working properly. Try installing a severe duty clutch or upgrading to an electric set up.
    Dan..
  3. greg mgm
    greg mgm 1/2 ton status
    Apr 6, 2005
    152
    Pine Cove (near Idyllwild) CA
    I just went throught the same exact thing on my 454 truck. Long story short, the fan clutch was the culprit. A severe duty one is what I replaced it with, and there's no overheating any more. By the way, I tried the highest CFM elec fans that Flex a Lite makes, and they couldnt keep the engine cool while towing, or at freeway speeds. I highly recommend against them for big blocks if you do heavy duty towing.
  4. afroman006
    Aug 21, 2002
    2,876
    So where would I get one of these "severe duty" clutches? How much do they cost compared to a stock 454 or 6.5 one? I wont even consider switching to electric fans, as this is my DD and I resolved to not do ANY significant mods to it.
  5. greg mgm
    Apr 6, 2005
    152
    Afroman- Good answer!! No electric fans!! Anyway, I found one at my local independant auto parts store. The clutch was a Hayden, and I paid $75 for it. The application was for a "454 severe duty" Money well spent.
  6. opfor2
    Oct 28, 2002
    375
    Ventura County, CA
    Most parts store should be able to order them for you. I've noticed that they stock the heavy duty / standard ones but the severe duty's are special order. No biggie, they cost a lil more but money well spent.
    Dan..
